331-350
351-370
371-390
391-410
411-430
431-442
my previous note wasn't clear!
<< P.S. In sketchup a minus of "section plane" is that you can have only one section plane active (there are workarounds using groups or components but the workflow is not so easy)>>
I meant ... you can have only one section plane active at the same time!!
Here an example from Rhino:
3D model with 2 clipping planes INACTIVE:
3D model with clipping plane 1 ACTIVE:
3D model with clipping plane 2 ACTIVE:
3D model with clipping plane 1 and 2 ACTIVE at the same time:
More infos ;)
So yes not excatly the same system :)
Else you have also this Cool plug Zorro2 by Whaat
Of course you must all explode before but you will have any number of Slice sections ;)
It's been quite a while since I played with older versions of Moi3d. It seems some kind of N-sided patch or blend between more than 2 edges has been a want for a while. Is this already in or planned for the v3 beta?
thanks,
Dan
Hi Dan,
These are not in yet but I am definitely trying to target them for v3. I've put in a fair amount of research time into N-sided blend already but it is a finicky area and I do not yet have anything that gives good enough results yet.
Michael.
So if Solids++ doesn't get updated fairly soon, where does this leave things?
It sounds like too big a task for just one person to take on (you) :) and it seems to me that the only other option would appear to be a change of kernel within MoI, or is there some other way to get around this?
Martin (2).
Hi Martin, there is some work currently in progress in this particular area by Solids++, but I'm waiting for bug fixes to it before I'll know whether it's going to work well enough or not.
If it doesn't work well enough then I'll probably work on developing my own. That's not impossible, just quite a bit of work.
Hi Michael!
I'm not sure I asked for this request before:
You know how you can control the 'start position' of a Blend or a Loft surface if they are made between closed surface edges.
I run into the need for this often, especially on more complex shapes. And by complex, I mean sometimes a simple bend.
I say to myself: First, wouldn't it be nice to be able to control some point in the middle of a Blend or Loft result surface - on an open surface?
And second, wouldn't it be nice to say, add any amount of control to-and-from points along each edge to tweak the result a little more?
This may already be part of your plans to add things like dual-bulge control and whatnot to Blends.
I think I saw a guy add this extra control to a blend or loft in a Rhino tutorial one time - and I did a double-take and thought "what the heck did he just do?".
This would have good uses... say a particular lumpy area or bump wants to appear but the rest of the Blend looks great... add a little tweaking point-set (like on the closed surface Blends) and thus a little control on the result. :-)
It's okay with me if this goes somewhere deep in the suggestion box. Because I'd still like to see Blending between edges made up of multiple (separate, but joined) surface edges, and that dual or Blend-bulge control thing...
Okay... idea done.
BTW, if I have time, I'd like to make this WIP my next tutorial: :-)
A plastic institution chair, but it's more subtly complex than it looks.
A special color for the generator curves
or maybe this is yet existing in the moi. ini ?
I try not to use special fixed colors for objects in MoI to convey special information other than for selection, because there is already a feature where you can control curve and surface color yourself by assigning styles to them and using the styles as a way to visually distinguish different groups.
Every kind of special color that is used for a different purpose then makes it hard for that color to be used as a style color, and also if a curve would use a special color in some circumstances would it override the style color?
So that would kind of come into general conflict with the already existing feature that you can control curve colors by their style assignment.
Hi Pilou, one thing that I do want to do in the future though is to have some different "display modes" that you could switch between which could override the regular display. Stuff like zebra stripes, and showing backfaces might work like that, and maybe a special color for generator curves could be set up as one of the things that you could have in one of those display modes.
> display modes...
And.... something quick and easy to store and recall all those cool lighting mode combinations I use. ;-)
"Ahhhhhhhhhhhh!" (angels singing)
Hi Michael, hope you had a good Memorial weekend - just thought I sneak this one in (again.) ;-)
Hi Mike, well shearing and rotation are kind of different operations, so I'm not so sure about grouping it under rotation like that...
I think that there eventually be a "cage deformation" tool under Transform > Deform, and then you'll be able to do a shear by doing a minimal 4 point cage and then sliding 2 upper points over.
You can get that same effect right now by using flow, draw a base plane using Draw solid > Rectangle, then duplicate that and turn on control points, shift the upper 2 plane control points over to make a sheared rectangle, then you should be able to use Flow from the regular plane to the sheared plane to make a shear happen right now.
Thanks Michael,
Whoa! You actually could foresee a "Cage" deformation tool in the future? ...that would be the next best thing to Flow.
Would we be able to re-orient the "cage" in 3D space separate from the object?
Yeah, didn't think the Rotation and Shear types were too related.
And yes, I tried the Flow method of shearing today just for fun, works great!
However, as I've seen in a demonstration (by another app), having a Shear tool that works like MoI's Rotate and Move have the potential to yield ungodly amounts of precision.
Plus you could use it within a structure, such as on a selected bunch of control points, or use it just on a shape, say in the middle of a Loft while it has history.
Hi Mike,
Yeah I think it will eventually be the third tool that goes under Transform > Deform.
I don't know any specific details about it yet, it's still a ways off from being designed.
Thanks Michael, good luck!
I'm still holding out for a circular selection function...
I think you mentioned that it may be possible to add or remove isocurve control elements (or row of grid points) within a surface, basically allowing for more or less definition in that surface.
With that idea, I realized that it might be possible to move the position of the "seam" on a closed surface without disturbing the surface... or maybe I saw this somewhere.
It's not possible now, but would be useful for times when you needed to use Blend to close the open end of a closed surface, among other things.
Could this be a feature nestled within some other feature?
So, a way to re-adjust the position of the seam on a closed surface... possible?
Uh oh... I think I just asked for the '3D' version to moving the (start/end) seam point in a closed curve.
(back-burner, just an idea)
Hi Mike, I do want to add a "relocate closed surface seam" mechanism, but it will probably have to be a specialized tool to do it, I don't really see how it would be bundled in to some other already existing function... Or do you have a particular feature that you were thinking of that would include this as some kind of extension to it?
Michael,
I do see where it could use a specific tool command. Especially if you could apply it to closed curves as well as closed surfaces.
Not sure which menu beside 'Edit'.
Maybe it would start life as a text command like "Rebuild"?
Mike
331-350
351-370
371-390
391-410
411-430
431-442
