Full Version: Top 5 Features list for V3 !
Show messages:  1-3  …  324-343  344-363  364-383  384-403  404-423  424-442
19 Sep 2012   [#384] In reply to [#383]
Hi wireframeX,
> Workplane is the first thing I need for now
Check out the Construction Plane tool under View > CPlane, more info here:
http://moi3d.com/2.0/docs/moi_command_reference5.htm#cplane
20 Sep 2012   [#385]
Does exist a whish list for the V3 like this one ?
http://moi3d.com/wiki/Wishlist
20 Sep 2012   [#386] In reply to [#385]
I've just been using this particular thread in the forum as the V3 wishlist.
20 Sep 2012   [#387] In reply to [#384]
Wow thanks !!!
Didn't view it ....
20 Sep 2012   [#388] In reply to [#382]
I'm also interested to a function similar to "section plane" of SketchUp.
In Rhino a similar function is "clipping plane" and you can define as many clipping planes as you need defining also thickness and colour of the section border with the possibility to have or not a filled cap (if the volume clipped is a solid). In other SW you can define also clipping volumes.
For complex structures, AEC, and assemblies it is a feature really important.
Giovanni
P.S. In sketchup a minus of "section plane" is that you can have only one section plane active (there are workarounds using groups or components but the workflow is not so easy)
20 Sep 2012   [#389] In reply to [#388]
<< P.S. In sketchup a minus of "section plane" is that you can have only one section plane active (there are workarounds using groups or components but the workflow is not so easy)
What is difficult in this? ;)
20 Sep 2012   [#390] In reply to [#389]
Hi Michael ...
Another one I would like: Styles ... I would like to be able to drag and drop a style into a new location. I know I can do this with the up and down but now that I have added many colors I have many, many styles and it is slow and difficult to add one and not relocate it by alphabetizing (all my colors are now at the bottom of the list and I want to leave them there ... yes, I could rename them to start with z but this is a big job). another assist would be a 'match' option so I could assign these new colors to new names more easily.
cheers
eric
21 Sep 2012   [#391] In reply to [#389]
my previous note wasn't clear!
<< P.S. In sketchup a minus of "section plane" is that you can have only one section plane active (there are workarounds using groups or components but the workflow is not so easy)>>
I meant ... you can have only one section plane active at the same time!!
Here an example from Rhino:
3D model with 2 clipping planes INACTIVE:
3D model with clipping plane 1 ACTIVE:
3D model with clipping plane 2 ACTIVE:
3D model with clipping plane 1 and 2 ACTIVE at the same time:
21 Sep 2012   [#392] In reply to [#391]
More infos ;)
So yes not excatly the same system :)
Else you have also this Cool plug Zorro2 by Whaat
Of course you must all explode before but you will have any number of Slice sections ;)
19 Dec 2012   [#393] In reply to [#392]
It's been quite a while since I played with older versions of Moi3d. It seems some kind of N-sided patch or blend between more than 2 edges has been a want for a while. Is this already in or planned for the v3 beta?
thanks,
Dan
19 Dec 2012   [#394] In reply to [#393]
Hi Dan,
These are not in yet but I am definitely trying to target them for v3. I've put in a fair amount of research time into N-sided blend already but it is a finicky area and I do not yet have anything that gives good enough results yet.
19 Dec 2012   [#395] In reply to [#394]
Michael.
So if Solids++ doesn't get updated fairly soon, where does this leave things?
It sounds like too big a task for just one person to take on (you) :) and it seems to me that the only other option would appear to be a change of kernel within MoI, or is there some other way to get around this?
Martin (2).
19 Dec 2012   [#396] In reply to [#395]
Hi Martin, there is some work currently in progress in this particular area by Solids++, but I'm waiting for bug fixes to it before I'll know whether it's going to work well enough or not.
If it doesn't work well enough then I'll probably work on developing my own. That's not impossible, just quite a bit of work.
26 Apr 2013   [#397]
Hi Michael!
I'm not sure I asked for this request before:
You know how you can control the 'start position' of a Blend or a Loft surface if they are made between closed surface edges.
I run into the need for this often, especially on more complex shapes. And by complex, I mean sometimes a simple bend.
I say to myself: First, wouldn't it be nice to be able to control some point in the middle of a Blend or Loft result surface - on an open surface?
And second, wouldn't it be nice to say, add any amount of control to-and-from points along each edge to tweak the result a little more?
This may already be part of your plans to add things like dual-bulge control and whatnot to Blends.
I think I saw a guy add this extra control to a blend or loft in a Rhino tutorial one time - and I did a double-take and thought "what the heck did he just do?".
This would have good uses... say a particular lumpy area or bump wants to appear but the rest of the Blend looks great... add a little tweaking point-set (like on the closed surface Blends) and thus a little control on the result. :-)
It's okay with me if this goes somewhere deep in the suggestion box. Because I'd still like to see Blending between edges made up of multiple (separate, but joined) surface edges, and that dual or Blend-bulge control thing...
Okay... idea done.
BTW, if I have time, I'd like to make this WIP my next tutorial: :-)
A plastic institution chair, but it's more subtly complex than it looks.
20 May 2013   [#398]
A special color for the generator curves
or maybe this is yet existing in the moi. ini ?
20 May 2013   [#399] In reply to [#398]
I try not to use special fixed colors for objects in MoI to convey special information other than for selection, because there is already a feature where you can control curve and surface color yourself by assigning styles to them and using the styles as a way to visually distinguish different groups.
Every kind of special color that is used for a different purpose then makes it hard for that color to be used as a style color, and also if a curve would use a special color in some circumstances would it override the style color?
So that would kind of come into general conflict with the already existing feature that you can control curve colors by their style assignment.
20 May 2013   [#400] In reply to [#399]
Hi Pilou, one thing that I do want to do in the future though is to have some different "display modes" that you could switch between which could override the regular display. Stuff like zebra stripes, and showing backfaces might work like that, and maybe a special color for generator curves could be set up as one of the things that you could have in one of those display modes.
20 May 2013   [#401] In reply to [#400]
> display modes...
And.... something quick and easy to store and recall all those cool lighting mode combinations I use. ;-)
28 May 2013   [#402]
"Ahhhhhhhhhhhh!" (angels singing)
Hi Michael, hope you had a good Memorial weekend - just thought I sneak this one in (again.) ;-)
28 May 2013   [#403] In reply to [#402]
Hi Mike, well shearing and rotation are kind of different operations, so I'm not so sure about grouping it under rotation like that...
I think that there eventually be a "cage deformation" tool under Transform > Deform, and then you'll be able to do a shear by doing a minimal 4 point cage and then sliding 2 upper points over.
You can get that same effect right now by using flow, draw a base plane using Draw solid > Rectangle, then duplicate that and turn on control points, shift the upper 2 plane control points over to make a sheared rectangle, then you should be able to use Flow from the regular plane to the sheared plane to make a shear happen right now.
