Full Version: Top 5 Features list for V3 !
Show messages:  1-5  …  246-265  266-285  286-305  306-325  326-345  346-365  366-385  …  426-442
12 May 2012   [#306] In reply to [#305]
Hi Jan, well those tools are not really everyday use kind of tools for general surfacing, they're kind of finicky and advanced tools that can get the job done if you don't mind spending a lot of money and also time involved in learning all the ins and outs of operating them.
That's because the "create apples from applesauce" direction is just not a very natural path to work with things...
So they probably are not a practical solution for you unless you are focused on reverse engineering surface models from laser scanned objects as your primary focus for your work.
-Michael
12 May 2012   [#307] In reply to [#289]
Hi Jan - re: golden ratio snap onto a line, I've cooked up something for that here:
script: /* Set golden ratio snap on a selected line */ var crvs = moi.geometryDatabase.getSelectedObjects().getCurves(); var pp = moi.ui.getActivePointPicker(); if ( crvs.length == 1 && pp ) { var crv = crvs.item(0); var start = crv.getStartPt(); var end = crv.getEndPt(); var phi = (1 + Math.sqrt(5)) / 2; var factor = phi / (phi + 1); var v = moi.vectorMath.makeVector( start, end ); v.scale( factor ); var pt = moi.vectorMath.add( start, v ); pp.addSnapPoint( pt, 'Golden' ); v = moi.vectorMath.makeVector( end, start ); v.scale( factor ); pt = moi.vectorMath.add( end, v ); pp.addSnapPoint( pt, 'Golden' ); }
Copy that whole thing and paste it into the command part of a new shortcut key.
That will then make it possible to use a new golden ratio snap onto a selected line while you are inside of any drawing tool (like draw line, draw point, etc...).
To use it, before you start the draw tool you must first select the line that you want to use for the ratio and it should be the only selected curve object.
Then start up whichever drawing tool you want and when it is asking you for a point to place, then press the shortcut key that you assigned the script to and it should give you a snap like so:
I hope that's helpful for your work!
12 May 2012   [#308] In reply to [#303]
Hi BurrMan,
that really is interesting! Thank you for that!
It seems this Rhino plug-in does a really good job in creating a NURBS model based on
polygon meshes.
By the named price of EUR 400 for this tool I am not going to ask you or Michael what the
'real ones' may cost.
But I like to try out the demo versions, yet before that I have to get use to Rhino first,
which I just recently installed in its free Beta version. At the moment I have even a hard
time to draw a circle with this program and by this I do not even care about where on the
screen this happens... ;) So first steps first.
A true need for this tool I do not have besides my plain interest. The thought so started
by the initial idea about 'minimal surfaces' within MoI and Michael's efforts to make me
understand why that would sort of 'bust the scope' by the complexity of its genuine nature
and that also a work around by polygon meshing would also run into its own complexity.
But it is always good to know what tools are available, so thanks again for this link!
Jan
12 May 2012   [#309] In reply to [#307]
this is really a beautiful script!
Thank you very much for it, as it will really help to work with the 'golden ratio'!
And because 'G' is already in use for your 'golden rectangular' script, I choose
'L' in memory of Leonardo Da Vinci ... :)
I already played around with it and noticed two interesting effects so far.
If used on a an angeled line both snaps appear perfectly but interestingly the
scrips seems to interfere with the perpendicular help-line from this point, as
this option does not show up in activated 'golden snap' mode.
But this is no problem, as once a marker line is drawn on a golden snap, the
perpendicular help-line reappears in a second step of sketching.
The other interesting effect appears on curved lines:
The 'golden snap' also appears here and indicates the golden proportion of the
projection of that line. I will see if this behaviour will be constant for any curved
line and its projection, as this also offers an interesting possibility to work with!
So thanks again for your 'cooking' as it really makes working with the 'golden ratio'
taste much, much better! ;)
Jan
13 May 2012   [#310]
@Michael
Cool new script: a golden one! ;)
Seems
For a line find 2 golden points: cool
For curve find only one out of the curve (when it find ;)
@Lejan
About Sketchup for all that curves: Loft, NetWork, Surfaces...etc take the free versatile Fredo6's Curvy loft!
http://forums.sketchucation.com/viewtopic.php?t=28586
13 May 2012   [#311] In reply to [#310]
Fredo6's Curvy loft
thanks for the help with SketchUp, but this program and I are just not made for each other... ;)
The graphics in a modern 3D modeling program should just not remind me on my good old
Atari 600 xl, which pretty much did the same only with less colors... ;)
Jan
13 May 2012   [#312]
< are just not made for each other
It's nevertheless the more easy 3D program that you can find :)
13 May 2012   [#313]
I use the curves and the planar command in moi3d to make virtual friskets in Artrage.
It would be helpfull if i could see the Artrage canvas through the Moi3d viewport.
When i have finished the job in Moi,then i use copy-paste to place the result in Artrage.
Question : Is it possible to make the viewport transparent (like a alpha channel color), but not the cuves.
I did get inspired by this application : http://www.ptc.com/product/creo/sketch/
13 May 2012   [#314] In reply to [#308]
Hi Lejan,
""""""""""""""""""It seems this Rhino plug-in does a really good job in creating a NURBS model based on
polygon meshes.""""""""""
Be sure you are looking at the "standalone" version.. They dont need Rhino and are a bit cheaper.
Here is a link to the open mesh one to try:
http://www.resurf3d.com/mesh2snurbs.htm
This one works on obj closed forms:
http://www.resurf3d.com/Objmesh2solid.htm
But it will be more of a "fitting" than a re-creation... I didnt put enough time into the obj one to really be able to speak to it's output.. Maybe you can make the demo work well and report back!
13 May 2012   [#315]
Added ;)
http://moiscript.weebly.com/golden.html
PS About the Golden Rectangle : Snap Straight must be enable!
13 May 2012   [#316]
Not a list of five, but a one i discovered i needed today - Crash Recovery file ?
Martin
13 May 2012   [#317] In reply to [#316]
Hi Martin,
If there is a crash, a dialog will pop up that has a Save button on it which will allow you to save out the current model data to a new file - that would be the crash recovery file right there.
In certain kinds of crashes like ones relating to totally running out of memory it could be possible that the conditions that caused the crash prevent the recovery mechanism from working though. But with a more regular type of crash instead of an "out of memory" type one you should be able to get what you are asking about I think.
Also if you run into a crash there will be a crash dump file created called moi_report1.zip (or moi_report2.zip, etc...) that can contain some information about where in particular the crash happened - if one of those were generated please send those to me through e-mail at moi@moi3d.com so I can try to pinpoint and fix the bug.
If your crash is related to totally running out of memory it can prevent the crash dump report from being generated too though - generally if your crash is related to that the main fix is to avoid overloading things to the point where are close to totally exhausting memory in the first place - that might mean breaking a super huge file into some smaller files instead.
Also if you have a 3DM file where you can repeat the crash easily with a certain operation it can help a lot if you send me that model file as well, since the easiest way to debug a crash is when I can actually repeat it over here.
13 May 2012   [#318] In reply to [#317]
This crash is not related to MoI, something makes this pc go to BSOD whilst it is in sleep mode, and i have never managed to track it down but will build a new toy soon :) just need to get the wedding out of the way first! But whilst on this kind of subject, is there an autosave feature ?
Thanks for the reply
Martin
13 May 2012   [#319] In reply to [#318]
Hi Martin,
No, not currently. Autosave can tend to be rather intrusive once you get to a fair sized model.
If your computer tends to blue screen when coming out of sleep mode, probably you should go to Control Panel > Power Options, and set it so that it does not ever go into sleep mode, you can set it to "System standby: Never" to do that I think.
Also the blue screen is probably caused by one particular buggy driver misbehaving - if you configure your system to create crash dumps on blue screens (Control panel > System > Advanced > "Startup and Recovery" settings > Write debugging information set to "Small memory dump") that could make it possible to look at the crash dump and maybe get a clue which particular driver is the culprit, then you could disable that particular one or try to update it.
13 May 2012   [#320] In reply to [#319]
This is a 0x1A crash and says it's to do with memory, but I still can't hunt it down, but my computer also bombs our V-Ray and rhino which is a pain in the butt, however that behaviour does not BSOD, but this is the only computer that i have ever had that crash's whilst it is in actual sleep mode. I can get busy doing things for my disabled partner and the screen will go from log-on/welcome screen to "no video available" - set by my screen when the pc goes to sleep, and then sometimes you walk past and for some unknown reason the BSOD is there.
Beats me - lol
Could be dodgy RAM or maybe a core on the CPU, or possibly the graphics card and the way windows 7 now uses virtual memory with video memory, all i know is that its a pain.
Martin
13 May 2012   [#321] In reply to [#320]
Hi Martin, yeah to stabilize it you've got to try and narrow down what's the bad part.
For bad RAM the best way to test it is to use memtest86 http://www.memtest.org/ (you need to set up some kind of bootable method like set up a bootable USB key or CD-ROM), and let it run for a few hours or overnight and if it detects a failure, you can be pretty certain that it's bad RAM.
If you can get a failure on memtest86 then replacing the RAM would probably be your best bet. Or if you have multiple RAM slots filled you could try removing just one of them at a time and re-run memtest86 to see which one is the bad one.
13 May 2012   [#322] In reply to [#309]
Hi Jan - re: golden ratio snap on a bendy curve instead of a straight line - what will happen in that case is that you'll get the ratio snap on an imaginary line between the curve's endpoints.
This looks like something that needs to be tuned up in the snap engine - right now it appears that a "script added" snap like this does not get processed with the same stuff as other snaps in regard to things that use other properties of the object the snap point is on.
13 May 2012   [#323] In reply to [#313]
Hi Paolo,
You could do that by taking a snapshot of the Artrage canvas and saving it as an image file, and then bringing that image file into MoI as a background image, using the View > Image command:
http://moi3d.com/2.0/docs/moi_command_reference5.htm#image
> but not the cuves.
No, there's no mechanism for making the viewport transparent in such a way as to actually expose totally separate application windows behind the MoI window - but the background image mechanism is set up so that you can place an image as the background of the viewport and have your curves drawn on top of it.
Basically the tracing mechanism in MoI is oriented towards tracing over an image, not for tracing over separate running applications. So you need to take a snapshot of your other application and put it into an image file to get what you are asking here - once it is in image form then you can use the background image mechanism for tracing over it.
13 May 2012   [#324] In reply to [#321]
I love memtest86 - I run it on all my computers after i have built them up and they get left on that for at least 10 full cycles or even up to 24 hours. Admittedly this RAM has not been re-tested and it's now very nearly a year old. I hate trying to solve intermittent failures like this because you think you have it sorted right up to the point where it does it again.
I have been a staunch fan of AMD processors but their continuing failure to keep up with Intel is starting to sway my opinion, once the new Bulldozer II's are on the scene and have been tested i will bet in a better position to say what the new box will have inside it ? Now that I am favouring MoI over Rhino these days do you have to or intend to do any code tweaking to make MoI more responsive to AMD's single core based application problems (AMD's new processors suck on applications that do not use more than on core) or is this problem down to MicroSoft and AMD to sort out ?
Martin
14 May 2012   [#325] In reply to [#324]
Hi Martin, well it sounds like you already know how to handle it!
Yeah intermittent failures are definitely the worst, and sometimes there isn't any really good way to solve them aside from one-by-one swapping components out with a new one, but of course that requires a duplicate set of all your system components to be available.
But if you can reproduce the failure while running under memtest86 that should really help to narrow it down though since it should take other stuff like the video card out of the picture and probably then more directly point to bad RAM or I suppose possibly the CPU but most likely RAM.
From what you are describing behavior wise bad/flaky RAM does sound most likely.
Intel certainly does seem to be a fair ways out in front these days I guess unless you are running some kinds of server oriented stuff.
I myself have just recently built a new box with a Core i5 in it, which has a reasonable price.
There doesn't seem to be anything particularly wrong with the AMD stuff, it's just lagging behind in performance to a certain degree but certainly will certainly still work fine in general.
I do intend in the future to add more things that take advantage of multiple CPU cores. But dealing with parallel execution tends to be very tricky though, and it's notoriously easy to create really difficult to nail down bugs with it, so it tends to be a particularly delicate and time consuming area of coding work.
