Full Version: Top 5 Features list for V3 !
Show messages:  1-8  9-28  29-48  49-68  69-88  89-108  …  429-442
25 Jun 2010   [#29] In reply to [#1]
My wishlist:
1) Groups
2) Filleting improvements to make it friendlier to inexperienced users (e.g. feedback as to what went wrong when it didn't succeed)
3) Would like to be able to wrap text rounds solids easily
Dan
25 Jun 2010   [#30]
Mine:
1. Groups
2. Instances
3. Supported API with easy external interfaces for parametrics
4. Multiple monitor support
5. Constraints, at least for 2D drawing
None of these, I know, are surprises.
/Ella
25 Jun 2010   [#31]
Couple more from me:
Bend tool or bend deformer
Deform to curve deformer
In both cases it's often best to model something straight then bend it once finished.
And if you want to go the whole hog then add bulge, twist, taper and cage deformers.
Nigel
27 Jun 2010   [#32]
> All the tools simultaneously on screen.
FiL
28 Jun 2010   [#33] In reply to [#32]
Yes
Brian
28 Jun 2010   [#34]
Add vote for all tools visible at once. Be nice to be able to have them on my second monitor as well.
Nigel
5 Jul 2010   [#35]
Great list so far!!
Here's mine::
-Transform object to follow along a curve.
-2d Flattening of a 3d object.
-Variable width fillet.
-Improved Blend.
-That-Astounding-tool-that-only-the-author-of-this-software-can-imagine.
I would like Instances but only if it's relatively easy to implement as I rather see improvement in modeling.
Marc
21 Jul 2010   [#36]
Here is mine;
-grouping is very important.
-I don't know how difficult is to do, but it would be great if you can extend parametric capability of the commands beyond the command execution and to be able to change the parameter of the objects after the command is executed. For example in array command after the execution of the command MOI will makes a " array group" and with another command or by clicking on the group (edit array) will be able o change the parameters value.
-Surface panelization. Right now is possible to divide a surface, all we need to assign any object to divided surface sections.
If I get any of these, i will be very happy, If not I am still very happy with MOI.
Sharif
21 Jul 2010   [#37]
Yeah I quite like the idea of an "Array group". Sounds similar to some of the generator objects in Cinema 4D where you place an object as a child object of a generator object e.g. Array object or MoGraph cloner object. The settings of the Array object or Cloner object can be adjusted any time.
Object grouping is probably the number one thing for me.
A few things like the menus need expanding so you don't have to keep adding scripts for everything. e.g. incremental save
I would also like more flexibility with windows. Sometime I want just 2 windows e.g. top and perspective.
Nigel
21 Jul 2010   [#38]
Something else I would like to see is the style colour that's assigned to a named object be displayed next to the name of the object in the browser. The object then doesn't have to be selected to see what style is assigned to it.
Nigel
21 Jul 2010   [#39]
Gotta add my vote for the deformation tools in V3.
Grouping would also be a huge help.
Looking forward to the next round of betas with beta'd breath!
22 Jul 2010   [#40]
A very simple :)
Rotation along a curve
Now it's not so simple: Array curve + align to surface is some tiedous
Array circular + Vertical step is along a line
Or maybe someone has a trick?
25 Jul 2010   [#41] In reply to [#40]
My top 5:
1. grouping
2. more selection tools
3. easier to configure interface with dual screen support - e.g. tear off tabs or tools on second screen
4. deformation tools
5. That-Astounding-tool-that-only-the-author-of-this-software-can-imagine - I'm with Marc :)
plus all the usual goodies that Michael always has in mind.
26 Jul 2010   [#42]
For me just a couple things:
I'd like the option of more traditional transform tools (see Maya or Softimage as good examples). I really like what's there but sometimes the traditional way is just faster. (PS I'd like to add MoI's tools to Maya and SI too!)
A variable radius fillet would be very useful.
64bit would be useful to me. I need more RAM access.
2 Aug 2010   [#43] In reply to [#42]
I think this had been discussed before by you also michael. Just wanted to be sure and list it in. When working on Blend, taking a look at adding the ability to control the bulge placement and direction. So a flip and perhaps a slider for the buldge location. :)
2 Aug 2010   [#44] In reply to [#43]
Hi Burr, could you maybe describe a bit what you mean by "bulge location" ?
The way Blend works, there's basically a kind of bulging happening at every single location along the blend, the bulge factor controls whether you want something that's kind of taut like this:
Or whether the blend shape bulges out more from its connecting edges like this:
But that kind of shaping is something that comes into play at every single connection point between the 2 edges, it's not like there is just 1 single point where there is a bulge, it's part of how every connection is made between the edges being blended.
2 Aug 2010   [#45]
Hi Michael and Burr,
We've discussed this here: http://moi3d.com/forum/index.php?webtag=MOI&msg=2915.1
Is this what you're talking about Burr?
2 Aug 2010   [#46] In reply to [#45]
"""""""""""Is this what you're talking about Burr?""""""""""""""
That Danny has a mind like a Steele Trap. Thats the thread I was refering to where it had been discussed before.
And then the flip, I'm not sure how/if that works...I understand it's about applying a curvature from the existing surfaces, but then to be able to flip/invert that could be some type of cavity tool. But, maybe thats just me looking for "wacky tools?"
But basically sliding the apex of the buldge around could be useful.
2 Aug 2010   [#47] In reply to [#46]
Hi Burr, sorry I'm still not sure if I'm understanding...
Do you mean a slider to control the bulge like this one here: ?
You can do this with the current Blend command by entering in a negative value for the bulge, that flips it to the opposite side, here's an example:
2 Aug 2010   [#48] In reply to [#47]
Well look at that...FLIP and I didnt even know it!! Presto!!! lol
As far as the other option, I envision it being an opprtunity to control the surface like this..
FIrst, this is a regular MoI blend with some bulge. Note the bulge favours one side (The strong side perhaps???) I've called dthis the apex.
The new slider would allow the control/ability to "slide" the bulges apex (Pardon the pun)
The values that Danny refers to in that other thread I read as this. The two number 1 values are the "Depth" at which the skew has to work. The number 2 value is the bulge as it remains now, and the number 3 value is the skew value, which slides the apex back and forth to be strong on one side or the other..
