53-72
73-92
93-112
113-132
133-152
153-172
173-192
433-442
Some noteworthy people have already mentioned these, but I'll reiterate since I think it's important.
1. Variable Fillet
2. Continuity options in more of the existing tools.
Those two alone would eliminate my need to use rhino every so often, and I think it would entice a lot of people to jump over to MoI.
Hi Steve,
> I guess our only way to affect a mesh/nurbs object
> globally then is to use a deformer (bend, etc)?
Yeah, and that actually involves some fairly fancy stuff like automatically rebuilding surfaces to have as many control points in them to flex to the amount of bending that is happening. But there has been some support for that kind of thing in the new release of the geometry library that MoI uses, so there is a pretty good chance at being able to get something going for that kind of deformation. I'll know more about this kind of deformation when I get a chance to dig into it in v3.
> When I mentioned falloffs I was thinking of the
> control points on a sphere , where you have multiple
> points and applying a fall off to that would help produce
> certain shapes.
Yeah, it would actually work in this case - when you have a simple sphere that has not been booleaned with anything, then it is an "untrimmed surface" - one where the trim curves are only around the natural boundary of the surface.
Those can be handled by pulling control points around like you would with a polygon mesh. But the problem is that once you boolean it with something else then the resulting booleaned object is made up of various trimmed surfaces and you can't easily pull any of those control points around anymore without tearing open holes between the different trimmed pieces.
So because it's kind of limited to certain special cases, this area of surface control point manipulation is kind of underdeveloped in MoI right now, I wanted to focus more effort initially in areas where NURBS have their greatest advantages compared to poly modeling, like boolean operations.
> I do have question/feature request if its possible.... Would
> it be possible to increase the control points on an object
> (such as a plane) or a cube, etc.
Yes, this will be possible - I do expect to flush out some of the surface control point functions in MoI as time goes on and this would be part of that.
If we ever get falloff tools I would like them to be ala Michael Gibson or at list ala Alias ;)
http://www.youtube.com/watch?feature=player_embedded&v=3z5VyVuKqTA#at=50
http://wikihelp.autodesk.com/Alias/enu/2012/Help/0061-What's_N61/0071-Modeling71/0080-Direct_S80
Michael could something like that be possible with the Solid++ deformation engine?
Hi adam,
I'm not really sure yet since I have not had a chance to dig into it in detail yet.
But I think it's possible that a kind of deform that is limited to only a small localized area is not really a great fit with the deform mechanism.
It's probably going to be more likely for stuff that warps the whole object.
But we'll see...
- michael
Michael ...
I would really like to be able to print directly from MoI ... or convert to pdf, once we have text and dimensions.
I know we can use SimLab Composer to do 3d pdf and that is great but I need to be able to print to 2d also.
So I hope that will be part of Ver 3
cheers,
eric
Why support textures? This program is a modeler and let it remain so! Extra instruments will only interfere with the work. And with the texture units can work in other programs.
Michael, good luck!
The main things I would like to see are:
Variable radius fillets
Continuity options for patches
Any chance for more file types for import/export?
Hi Nick,
Sure, it's possible. What formats did you have in mind?
Right now DXF, SVG, and PDF are kind of at the top of the list.
Import - *.wrl, *.dwg (3D data), pdf underlay
Export - 3D pdf, *.dwg, *.bip (for us Alibre users :-) )
Other than these I don't really have a "top 5." Even these are a "would be nice" feature and not something I would quit using MoI over.
Stuff that I would have in a top 5 you have already hinted at working on (mainly UI stuff).
Thanks!
Hi Nick, so there are some various difficulties with several of those formats.
.wrl is a polygon based format, things like a sphere in a .wrl file are made up of a lot of little triangular facets and not an actual smooth sphere surface. That's a pretty different type of data structure than the NURBS surfaces that MoI works with.
.dwg is a proprietary format from Autodesk which is not very easy to deal with without using some special kinds of libraries. There is a companion format called DXF which is actually documented (for 2D stuff anyway, NURBS solids are not documented).
.bip I don't think is publicly documented. I think it is a text file format so it could be possible to figure it out but having an official public document that describes the file structure helps a lot when trying to make an exporter for that format.
.bip is pretty specific to just one particular rendering program - just in general with MoI it's more feasible for me to work on file formats that tend to be used by a variety of different programs for file transfer instead of ones that are specific to just one program. OBJ format already contains the exact same kind of data that would go into a .bip file...
Thanks, like I said these are kind "nice to have" things, but no real biggie. I understand DXF, but find DWG to be more robust/feature rich for 3D and is of course an industry standard (despite being proprietary). Maybe I could amend this and request 3D DWF instead?
The API, specification, and toolkit are freely available.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=5801732
Thanks for listening,
Nick
Hi Nick, that's interesting that there is a toolkit available for DWF, I didn't know that existed.
What would be the benefit to you in having DWF output from MoI - is there a particular program that can only read in DWF format stuff and not any other formats?
I'm not really all that familiar with DWF myself - I guess it is basically trying to do the same job as PDF though? What are the advantages that you see compared to PDF?
I took a quick glance at it, and in some ways it seems to be a kind of complex file format, in that there are kind of various totally different sub formats within it, like 3D data is contained in a completely different kind of internal document than 2D data, etc... PDF is kind of like that as well though, with 3D PDF content being basically a completely different kind of structure kind of tacked on.
You are correct with the two different froms for 2D vs. 3D. The reason for that is the 2D data (in some sort of xml format) is readable by the Microsoft XPS viewer which is included with Windows, so basically any windows (Vista +) computer can read 2D DWF data without any other program installed. This ability is limited to the DWFx format (which is kind of the new defacto).
The advantages of DWF over pdf are file size, and a more robust 3D viewer in addition to free markup tools (Adsk Design Review). DWF really is a more CAD-centric format than PDF. I *think* 3D pdf was kind of a reaction to DWF and is now in the hands of Tetra 4D (?) instead of Adobe. It's a good way to hand over a design for review without actually handing over the design. There aren't any specific programs (besides Design Review) that only accept DWF that I am aware of.
It has it's uses, but is not going to be a "Wow, I'm sold!" feature.
I attached a quick demo dwf (just some basic shapes). Note: only 2D stuff will show in xps viewer.
Drawing2.dwfx
Hi Nick, I see - that could definitely be useful as a viewing mechanism.
That kind of thing is probably more on the back burner as compared to adding formats that are more about transferring data to be used by other CAD or illustration programs though.
2D PDF being generally similar in functionality but kind of more widespread would probably come first before DWF.
The only other thing - and I don't know how it compares to 3D pdf, but the 3D data can be extracted. I have been playing on and off with IMSI DoubleCAD and it (probably TurboCAD as well) actually imports dwf 3D models and allows the use/editing of those models. Of course accuracy is compromised when that is done.
That's kind of what I figured. I have been trying for years to get clients to switch to dwf the file sizes are almost half of the same pdf (2D vs. 2D). I don't have or know of any programs that do both 3D pdf and 3D dwf so I can't compare 3D files.
Michael,
I have two request and unfortunately they are not low-hanging fruit. One I have asked about in the past, and I am sure others have also, which is a Mac version.
The other request will probably illustrate a severe lack of knowledge on my part, but I would like a way to convert my beautiful N-gon mesh to quads. I like how quickly I can make a model in MOI, but if I import the mesh as a obj they are unusable in ZBrush for sculpting.
This turns out to be such problem that I recently bought Modo, which allows me to add edge loops on my SubD models to have a nice quad mesh.
I am not sure how tough it would be to reduce the amount of tris generated during export, but it would help if I only had to make a few modifications in Modo or Maya, instead of having to retopo the whole mesh.
Regards,
Paul
Hi Paul, yeah unfortunately both of those are quite difficult things.
I am making some progress on converting the UI to a system that will be more feasible to run on other operating systems, so that's a step towards that but there may be several other big steps needed as well. So I'm not sure when that will actually happen. Meanwhile it is possible to run MoI on your Mac right now using the Parallels or VMWare virtualization systems.
That's a much more difficult problem, since it would require a very different meshing mechanism, basically it would need to tile some kinds of complex outlines with a small pattern of quads. See these previous posts for some more description:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1244.48
http://moi3d.com/forum/index.php?webtag=MOI&msg=3854.15
http://moi3d.com/forum/index.php?webtag=MOI&msg=2451.50
http://moi3d.com/forum/index.php?webtag=MOI&msg=3869.64
You can get an export for sculpting in ZBrush using some settings to divide the mesh into small pieces - also don't export using n-gons since ZBrush does not like to deal with n-gons, use "Output: Quads & Triangles" instead.
For dividing the mesh, enter a distance value in the "Divide larger than" setting to subdivide the mesh into little fragments, that can then be manipulated in ZBrush.
See here for some examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=804.26
http://moi3d.com/forum/index.php?webtag=MOI&msg=2833.5
Meanwhile I think, the topologie of a NURBS surface is something special and it is very difficult or not possible to transfer it to polymodellers. I find, that this NURBS surfaces are better then all the others, probably of it´s mathematical concept, which creates them.
In my opinion it should be the task of programs like Modo, Blender and so on, to develope an importer for .3dm.
I say this, because i think it is better for Moi, that Micheal concentrates himself to develope MoI´s capabilities of making good surfaces,further.
I also would not need rendering and maesurement skills, for this I have TC, which has a .3dm importer. I have MoI because of it´s NURBSsurface skills.
Rudl
Hi Rudl, yeah so the difficulty is that using polygons for subdivision surface smoothing requires a very particular kind of topology which is having everything tiled into a pattern of quad faces.
That's a very different kind of topology than what MoI currently creates - for example with a shape like this:
MoI will create just 1 single polygon for the top face if you have n-gons enabled when exporting that shape to polygons.
To have all quads instead would mean tiling that top face with a bunch of little quad pieces instead, having them radiate out from the boundaries. The difficult part about that is when the quads from different boundaries collide into one another, that's in particular where a new topology would have to be created.
There are some special "retopologizing" tools that can be used to do that kind of conversion now - several polygon modeling tools have some tools to manage that kind of conversion. Topogun (
http://www.topogun.com/) is a full program dedicated to that task, and 3D-Coat has a good toolset for it as well. But yes, it's kind of something that is more likely to happen within a polygon modeling toolset than automatically from MoI.
53-72
73-92
93-112
113-132
133-152
153-172
173-192
433-442
