Full Version: Top 5 Features list for V3 !
Show messages:  1-20  21-40  41-60  61-80  …  441-442
21 Jun 2010   [#1]
Hello,
Well I know Michael don't like roadmap, (I don't like planing myself :)), but I just want to express some features I would really love to see in the new V3.
And of course, I'm listening from you guys what would be your dream list ! ... might be usefull, or maybe not ...
- multiple edges blending at once.
- fillet improvement (I know we rely on the Nurbs++ library, but I still feel frustrated with this tool)
- some surface continuity options for the sweep, loft and network tool.
- Display perfomance enhancement. I know one of the MoI key feature is the beautifull curves display, but I would really love to have an option to degrade this curves quality and speed-up the viewport).
- Lattice box deformation
21 Jun 2010   [#2] In reply to [#1]
As a new user I'm still getting up to speed but I agree about some sort of "Level of detail" as Cinema 4D would call it to improve viewport performance would be useful.
Probably number one for me would be parent child, groups etc. Pretty sure I read Michael wanted this in Version 2 but ran out of time. Coming from Cinema 4D I'm used to its excellent Object Manager for organizing scenes.
When I have a point selected I would rather the coordinates display continue to display that point's position rather than the position of the cursor. Or if I have multiple objects selected the coordinates is the average position of the centres of all of those objects. I would then be able to type in a new position. At the moment as far as I can tell I can only type in a position in the coordinates when I'm creating something. I would also like to be able to edit the positions of things after being created by just typing in the coordinates. I know this can be done with the Move Tool but I want a quick way of just entering a value for what's currently selected.
The option to change display mode should be built in rather than having to set up hotkeys with scripts. e.g. wireframe, box mode for complex scenes (box mode should also be available on a per object basis (Cinema 4D display tag))
No doubt I'll have more suggestions as I get the hang of this excellent application :)
Nigel
21 Jun 2010   [#3] In reply to [#1]
+1 with PaQ
21 Jun 2010   [#4] In reply to [#3]
hi, all
quoto PaQ
21 Jun 2010   [#5] In reply to [#2]
Hi Nigel,
This might fit in better in the object properties panel in the upper-right area of the window, in the same area where an object's bounding size is currently displayed.
With many situations, that averaged point is just some arbitrary point out in the middle of space between several of the selected objects, not necessarily at any key spot or even touching any object. My question is - what do you gain by setting the exact numeric position of such an arbitrary point?
21 Jun 2010   [#6]
Wishes for V3:
instancing system.
Ideally the instance could be kept as instances when exported to 3d programs such as modo and C4d, but this may be too much to ask.
Having instances for modeling would already be good.
Groups. I guess this will be coming soon.
Display enhancement.
Especially when I have a lot of lines, from imported plans for exemple, moi really slows down.
Would be nice if we could freeze all lines from one plan into one object.
21 Jun 2010   [#7] In reply to [#5]
Hi Micahel
>This might fit in better in the object properties panel in the upper-right area of the window, in the same area where an object's bounding size is currently displayed.<
That would work. That then leaves the coordinates at the bottom free to display the cursor position plus allow input.>My question is - what do you gain by setting the exact numeric position of such an arbitrary point?<
Probably I'm used to working in a polygon program like C4D and modo where objects or whatever is selected has a position. This isn't a major one and if no one else has asked for it then it's probably not an issue.
Re instances. While this would be handy in MoI for visualizing things I wouldn't get carried away about trying to export instances. Perhaps what could be exported is a point map if that's possible. Then in the 3D app like C4D or modo the one exported reference object could be instanced on to the point map.
Nigel
21 Jun 2010   [#8] In reply to [#7]
Hi Nigel,
Well, others have actually asked for it too, it's just something that I don't quite understand because it kind of gives the illusion that you're doing something accurately even when you're really not if the base point that is being placed comes from some arbitrary averaged spot.
I think that it can get added into MoI anyway at some point, but maybe in a secondary extended properties dialog and not at the very top level of the main UI.
22 Jun 2010   [#9] In reply to [#4]
Hi Marco,
For V3... work in progress...
FiL
VenetoStrings.txt
22 Jun 2010   [#10]
Hello,
1. Hidden line removal when exporting 2D vector images. MoI is unique already in it's great vector output quality using true curves, hidden line removal is icing on the cake.
2. Grouping would be a welcome addition.
3. The other suggestions are good, filleting improvements would be good.
22 Jun 2010   [#11]
Hello!
Ok than I start too :D (order of importance)
- Hidden Line export
(- Panelling Tool
- Finished group system)
22 Jun 2010   [#12]
As far as speeding up the viewport (level of detail), you can already do that. Just go to Options -> View and increase the Mesh Angle setting to reduce detail and speed things up.
22 Jun 2010   [#13] In reply to [#12]
Cool, lots of addition !
Hi SteveMacc,
Well actually I don't have any problem with the geometry itself, looks like it's more the curve overdraw that slow down the viewport when stuff are starting to be complex.
I get something like twice the framerate speed when I temporary hide the wireframe on heavy scene.
Anyway, I know it was allready discussed, but I couldn't resist to post it.
22 Jun 2010   [#14] In reply to [#12]
I imagine this may not be a realistic item but I could sure use part volume as a data output for a given model. I benchmark products and would love to model a part in MoI and obtain the volume on assemblies that do not come apart in a nondestructive way. Recently I lost my seat of SolidWorks to a real CAD guy (only so many seats to go around) so I've had to revert to doing a lot of calculations by hand.
Dreaming in Detroit :)
- David
22 Jun 2010   [#15]
A 3 axis CAM plugin with the same high level of quality, support and value of MoI. Oh, and variable radius fillets.
Bob
22 Jun 2010   [#16] In reply to [#15]
If Michael could have MoI get up and get me a beer every hour and a half or so...This would be nice and fit into the easy modeling tools category....:o
22 Jun 2010   [#17] In reply to [#16]
But where would you put beer in the UI Burr?
What if someone preferred a scotch or rum? And Mixers, where would you put the mixers?
... it's a minefield.
Mark
22 Jun 2010   [#18]
Hi
I need a ruler in order to control some distances...and a goniometer for angles...
FiL
22 Jun 2010   [#19] In reply to [#18]
Hi Fil, just a quick note on this:
Currently you can draw a line to find the distance between 2 points - while you are drawing the line look at the distance readout in the bottom toolbar, here:
Also once you have drawn a line you can select it and the length of it is displayed here:
There's also a plugin command that you can install to get a "Distance" command as well:
http://kyticka.webzdarma.cz/3d/moi/#MeasureDistance
22 Jun 2010   [#20] In reply to [#19]
Yes, but if I draw a line in order to control the distance between two points, at the end I've a line that not use...
Now I'll see the plugin.
Thank
FiL
