Full Version: MOI3D to Octane Render Tutorial
Show messages:  1-12  13-32  33-52  53-72  73-90
28 Apr 2010   [#73]
Yeah...like when can I fork over money for MOI3D Version 2.0!!!!
28 Apr 2010   [#74] In reply to [#73]
Pretty darn soon! :) This pesky documentation...
28 Apr 2010   [#75] In reply to [#72]
How are those docs going, anyway? Have you begun the latin translations, or are you still working on the iambic pentameter? =)
28 Apr 2010   [#76] In reply to [#75]
I'm afraid I'm still stuck on the Aramaic at the moment... :)
28 Apr 2010   [#77] In reply to [#76]
One times more, Michael, you show us how serious you are.
You have a software almost bug free, but you don't start selling it just because of the documentation. I really admire your way of work. Thanks for that!
4 May 2010   [#78] In reply to [#77]
with so many new vis apps coming out i was about to invest in this even though i don't have a CUDA GPU. looks like i read this in time. Thea i'm testing atm and looks pretty good. i think in time it will become pretty powerfull, but somehow fryrender still feels the most professional renderer out there, with the best quality result, even though it lacks in areas.
hypershot and all the biased stuff out there just seems less and less enticing these days...
hey Michael, with all your spare time how about you make us an unbiased real-time renderer MOI style ;)
12 May 2010   [#79]
Hi all
Just to say the prob is solved. Radiance say:
<<we found the issue, it was a precision issue in the cuda kernel's normal interpolation/flipping.
fixed in upcoming 2.2.>>
12 May 2010   [#80] In reply to [#79]
That's good news. Maybe he'll put back the MoI logo on the home page :)
The new videos showing Octane ver 2.2 with dual GTX480 cards is impressive.
Ed
12 May 2010   [#81]
Hello,
He is just trying to cover himself now that the issue was cropping up with models generated in other applications. If Radiance is going to indicate true compatibility he needs to remove more logos, not add any at this point.
12 May 2010   [#82]
Looking good!
Here's a screenshot pf Micheal's previous "segmented cylinder"
Marc
12 May 2010   [#83] In reply to [#82]
That's a huge improvement Marc, that is now looking like it is supposed to!
So if that issue is fixed in Octane now, the only thing you should need to do when exporting from MoI is to uncheck the "Weld vertices along edges" option at export time.
Could you also try the single polygon file from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3472.40
What does that single polygon look like shaded in Octane now?
12 May 2010   [#84]
This is a test image posted the developers on the octane forum, the beta will be out later this week.
Looking forward to test it!
Marc
12 May 2010   [#85] In reply to [#84]
Hi Marc, well it certainly looks promising!
12 May 2010   [#86] In reply to [#82]
Cool, looks like the bug has finally been fixed. It would have been nice if Radiance had acknowledged the problem/fix in this thread, but I can understand him wanting to put things behind him. I hope there are no hard feelings about this issue. I don't know what took place with Paq in the private octane forums, but I assume he was only sticking to his guns while everyone was brushing him off. I think in the end Octane is a better product for his efforts, and it can now be fully embraced by the CAD community (which I would think to be a huge userbase for this kind of product).
That dual 480gtx video was nice, btw. These gpu based bi-directional path tracers are definitely going to change things over the next few years. Fun times.
13 May 2010   [#87]
The new release candidate is out now, I've tried Paq's superball and it seems to render fine as far as I can tell. But I don't have a lot of experience in this area so I hope other people with Octane license will jump to testing. The test cylinder shows no seams.
As for the flat polygon test - it mostly looks ok, there's some weird "shadow" creeping up from some angles, I don't know if this is related to vertex normals or the lighting system or what. But at least the polygon is shaded now.
13 May 2010   [#88] In reply to [#87]
Hi candide, that is looking way better, the vertex normals are definitely coming into effect there.
There should likely be a significant increase in render quality there now.
Most likely the only thing you need to do now is to uncheck "Weld vertices along edges" when you export from MoI.
> system or what.
Hmm, hard to tell what that is. If there is some reflection going on instead of only diffuse lighting, that could just be some reflection from the environment or something like that.
Or it could be something like individual vertex normals flipping to the opposite direction if they end up pointing opposite of the viewing direction. If that's the case then you wouldn't really see it on a more typical kind of mesh that doesn't have so much variation between the vertex normals on just one polygon.
14 May 2010   [#89]
Part of a model I struggled with before...
Marc
14 May 2010   [#90]
I just love when a software investment pays off - I'll give the latest version a good test this weekend! ;-)
-Will
