Full Version: SimLab Composer
Show messages:  1-13  14-33  34-53  54-73  74-93  94-106
9 Apr 2010   [#54]
SimLab works very well.... The ability of the Adobe 3D PDF to cut sections, zoom in, and let the user measure stuff saved my behind this week.
Had a complex item and the phone communications over images I send became rather bizarre. I bought that Composer, send the 3D PDF.
Had not heard from the client for two days and then simply received an approval...
Awesome
Rainer
Here's a sample I made. In any case... the render look deceptively cool. But they are 'simple' image based lit renders.
It's sort of a one trick pony render. No displacement but bump. And so on...
However... big bang for the buck! And -ZERO- setup time. Click -> and nice. Maybe not super... but always nice...
9 Apr 2010   [#55]
Hi Rainer,
Please take a look:
9 Apr 2010   [#56] In reply to [#50]
Hey Danny,
When I rotate Robby on my P4, the glass disappears and the "eye's start blinking" and the "little blue lights" blink also....It would have been hard to plan that any better!!!
IT'S ALIVE!!!!!
9 Apr 2010   [#57] In reply to [#52]
Hi candide,
> Besides 3D PDF, which I didn't know existed until now
> and I still don't understand the reason for its existence
> - what does it have going for it?
It can be helpful for communication. For example say you're working on a model for a client and you want to show them some intermediate results, and you'd like for them to be able to rotate around and view things from different angles but they do not actually have much direct experience in 3D modeling themselves.
In that kind of situation you can probably send them a 3D PDF file, which they can probably view on their system without needing to go through extra steps to install other software because they have the Acrobat reader installed already.
9 Apr 2010   [#58] In reply to [#55]
I know Ralf. But no Displacement. So, the bump/normal effect is busted when you look at the edges of the geometry.
But again.... that's not what it's made for. it's a quick tool and for that it works great. And 3D PDF has been a
great discovery for me...
R
9 Apr 2010   [#59] In reply to [#57]
Hi
testing simlab, I like the interface i have hypershot/keyshot and in many ways the interface is better. you loose realtime feedback but gain in being able to move scale parts easily. Also the lights render so its not just lit by HDRI. This you cant do in keyshot. In the pic i have placed a light in each lamp. got to play with the lamps to see if they can produce quality results i just used a really high number and i think that is causing the fireflies. rendered at default settings so some noise.
At the price a bargain renderer with the pdf stuff an added bonus. Render quality is exactly the same as hypershot as far as i can see.
Jamie
10 Apr 2010   [#60]
Have they already removed the special offer, i can't find it?
//Hep
10 Apr 2010   [#61]
Please take a look:
http://www.simlab-soft.com/3d-products/simlab-composer-main.aspx
11 Apr 2010   [#62] In reply to [#61]
Super, thanks
12 Apr 2010   [#63]
This software is cool until you dont work with textures(UVW map is very weak). and a lot things are missed. I think it is for only production rendering only...
12 Apr 2010   [#64] In reply to [#63]
I think it works for that price!
12 Apr 2010   [#65] In reply to [#63]
I'm extremely happy with my purchase too. If all it did was import different formats, copy models and allow me to position them before rendering I would still be happy. I love the renderer, and the license policy is a lot less of a hassle than my vray rhino license. It's also much easier to set up than vray. I just looked at it as a low cost high quality renderer. Everything else is extra.
12 Apr 2010   [#66] In reply to [#65]
Hello All,
thanks to this forum, I found what I needed for my rendering.
Was considering Keyshot, but $995 and only on one machine did not like those parts.
Simlab composer is great and did not have any problem importing from MOI. and easy to use, as I am not a computer guy.
attached is my first rendering with Simlab composer...will probably find its way through....
....anyway, of course, to me, the crown jewel is MOI.
Michael,
I am ready for V2.
Best,
Rudy
13 Apr 2010   [#67] In reply to [#65]
Rudy, I like the ring. It has just a touch of a retro art deco-ish kind of thing. It feels very masculine to me. I don't think it will work for a woman. Maybe it's just the angle though? Is it a man's ring?
13 Apr 2010   [#68]
Great render, Rudy, I'm glad that you've finally found a rendering app that fits your needs and saved you a bunch of cash too!
Plus you get the PDF export which is great for delivering to clients etc.
-Will
13 Apr 2010   [#69] In reply to [#66]
Rudy,
Very nice! I was unsure about SimsLab Composer for jewelry
renderings until I saw your ring.
Jesse
13 Apr 2010   [#70] In reply to [#69]
Hello all,
thank you.
Yes, simlab is great and very easy...it is my first attempt and haver to say it was pretty straight forward.
It is a man's ring.
Best,
Rudy
13 Apr 2010   [#71] In reply to [#66]
Hi Rudy,
Nice job on the design & render, Well done!!
Glad to hear you've found the SimLab Composer so easy to use with your first go, Congrats!!
I also considered buying this SimLab Composer...but I've already invested in V-Ray for Rhino, so couldn't see any real advantage to me.
regards Colin
15 Apr 2010   [#72]
An image sended by a Sim Lab composer team guy
it's not so bad ;)
15 Apr 2010   [#73]
No, it's not bad at all :) . That is some smooth modeling. Is it a nurbs or poly model?
