7-26
27-46
47-66
67-72
Hi NightCabbage,
> Any idea what I'm doing wrong?
Hard to say without examining the model file directly. Can you please post the 3DM model file (before shelling it) so I can check it out?
But it kind of looks like you may need to do an extrusion rather than a shell for the filling piece, because your shape is based on an extrusion rather than an offset.
Note that the angle used in my shape is different than your most recent one in this area here:
Your new one goes straight upwards, unlike your original one which was shaped more like mine I think?
Ah, yes, this is true :)
Though does this mean that it's harder to "inset" some shapes than others?
ie. the second one I made
Also shell - haha it's working quite well with my random shapes now, however for some reason, the last time I tried it (to "thicken" something) it didn't work properly - I'm not sure why! If it happens again I might post the 3dm file...
Thanks for the help and patience Michael - as always!
<3
Hi NightCabbage, no problem!
It can easily run into difficulty when thickening pieces made up of more than one surface, if the surfaces do not all attach to one another in a very regular angular pattern.
In cases like that you may need to separate the model into individual surfaces and thicken those surfaces - the thickening of a single surface should not run into the same kinds of difficulties.
Hopefully in the future it will be possible to thicken multi-surface objects more easily than what is done currently, but it will need a pretty big upgrade to the shelling component in the geometry library that MoI uses which is licensed from another company. I do have a request in to them with several examples to ask to improve this area, I'm not sure when that will happen though.
Shelling a solid works in a different way than trying to thicken a surface, so sometimes instead of thickening a surface you may want to finish the surfaces into a basic solid, then perform the shell on the solid. The sheller is more able to make clean matching pieces when there are side walls available to cut pieces with.
Hi NightCabbage,
> than others?
Probably that is true (that some things will be harder than others to inset with this method), but actually in the second one you made you just should use Extrude for the second step to build the plug pieces, rather than Shell for that step.
By default extrude will make faces extrude along their own face normal, use the "Set dir" option and click 2 points vertically to make the faces extrude along the vertical direction and then you will have your plug pieces.
If you have a larger solid and you're trying to inset just one small area of it, you probably won't be able to use the method I showed here because the shell will work more on the whole object. For something like that you'll need to work at kind of a lower level, doing Offset on the edge curves, then trimming or extruding, the kinds of steps that were shown in that previous link above.
Awesome! I just found out a cool way to do insets :)
You have the original shape, and you do a project of the curve shape you want to be inset onto it.
Then you network it, and extrude it into a solid.
Then boolean subtract it out.
Easy :D
One thing I find about MoI - it has so many "hidden" features!
eg. Boolean Difference can also be used as a "slice" tool
I had sorta asked Michael for this when I had mentioned to him that I had wished for a traditional Bevel and Extrude command for some faces I was working on.
Hopefully we'll get something like this in MoI soon - it would make my panel work so much faster and easier for sure!
-Will
I had an idea that I just had to try:
Tends to work best with blocky shapes though, where offsetting does not have problems.
That looks very cool Michael. What happens on trimmed curved surfaces?
Side note: I just noticed the "Set Flat Direction" option in the sweep flat command. This is cool too.
That was not yet possible with the offset shell function?
Shell is related but not the same - shell hollows out the entire object.
Like for example with this selection:
Shell hollows out the entire object and leaves those as openings, producing this result:
Shell produces a "thin wall" object.
An Inset on the other hand, does not go through the whole object and instead produces a result that is localized to those faces:
Wow!
Great Michael.
eric
Hi Burr,
It can depend on the shape, there can be difficulties in the offset calculations in a lot of cases. Also currently the pieces being inset must be bounded on all sides by sharp corners.
But there are a lot of trimmed curved surfaces that will work as well, like here is a sweep that has a hole booleaned out from it:
Woah!
Offset-shell-moveface combined!
Is this a special limited offer? Where do I order?
Marc
Effectively that is slighly different than the classical Shell :)
Michael - that's awesome :D
Looks like you've managed to add the feature very quickly and very well!
Hi NightCabbage, I'm sure that you will run into some cases where it will be frustrating that it won't work... The offsetting mechanism is not really at the same level of dependability as the boolean functions for example. It will help a lot to have very clean geometry, no things like little slivery bits or excess faces like 2 coplanar faces next to one another where there could instead be one large single plane.
But I believe it will still help you out in quite a lot of cases though. It should work well for changing a simple part into a more complex looking one extremely rapidly. Here's an example shape like you were asking about originally:
Brilliant!!
I think this will certainly be a great addition for those of us making jewellery related items.
regards Colin
Michael, really, thank you
so much for this!
I'm not sure though, is this considered to be a "regular" bevel / extrude function?
I like how you can inset a surface, and it appears to let you also extrude in the opposite direction - I just want to be sure if you don't actually consider this an extrude or bevel function.
Either way, having this will make a snap of my panel work in a lot of cases! ;-)
-Will
PS - Okay, looking again at the GIFs, this is basically an inset/extrude since beveling lets you also change the width of the new face(s) - which is not what's happening here.
This is an awesome function though, can't wait to have this!
7-26
27-46
47-66
67-72
