Show messages: All
1-6
7-11
:D
Thanks so much for the info!
I'm learning a lot!
I'm not sure how I managed to create extra egdes - oops! I'll have to keep an eye out for that sort of thing...
Also, it's going to be a hover tank - I'll post it, along with some others, after I've done a bit more work on them :P
(they only need to be simple, as they're going to be very small in my game)
Hi NightCabbage,
It's hard to say exactly how that happened without watching the steps you used...
But it kind of looks like you may be drawing in some separate curves for different surfaces rather than building them all off of a single shared curve framework.
There some other kinds of ways that could happen too though, like using a surfacing command that did not make use of some curves, like a one-rail sweep instead of two-rail sweep or network... possibly something like that anyway.
Ok, I've come across a problem, and I'm not sure what's causing it...
See the hole / overlap of the surface on the curves?
Why is it doing this?
(it's a network on some curves)
Trimming problem?
network fail.3dm
Hi NightCabbage - actually there is nothing wrong there at all, that's just a display artifact from getting a coarse display mesh in that area.
That can tend to happen in areas that are pretty shallowly curved - not quite enough triangles got added into that spot.
That is something I want to tune up in the future, but for now the solution is to just treat it as a side effect of the display and ignore it.
If you see a more chaotic appearance in areas like that, like with maybe some dark streaks, then that is something to be more worried about.
When you go to export, you will have a chance with the export mesher to get more polygons in those areas if you want by using the "Divide larger than" setting.
The display mesher is more oriented towards doing things very quickly and in some situations it takes some shortcuts which can have a slight visual side effect like you have run into here.
Oh, good! I was hoping it was something like that :)
Show messages: All
1-6
7-11
