Show messages: All
1-13
14-18
Perhaps it's a legacy of my background, but I often find myself wanting to position and rotate objects from their center points :)
Probably my default way of working, unless I want to align something with an edge of another object, etc. (whereupon the default MoI style is perfect)
Sorry Michael, I feel like I've been asking for so many feature requests over the last 24 hours! Just thought I'd post some of the things I'd been thinking about since learning MoI :)
Hi NightCabbage, well for rotation if you use the edit frame in a 2D viewport, that will rotate around its center point.
For example here I am rotating a box by using the rotation grip on the edit frame, notice how it rotates around its center:
Does that do what you want?
It would probably help me a lot if you could post some example models that showed me some instances where you wanted to do some of the things you are discussing, like move an object by its center point.
If you just want to move an object over a bit arbitrarily, you can grab any point to do that, you don't really need the center specifically for just pushing it over a bit or stuff like that.
If you want the center to align with other things, the Align command could probably do that job for you.
It's also possible to grab the midpoint between 2 points as the source for Move by using construction lines, maybe that would help you out in some circumstances.
But it is difficult for me to know for sure because I don't really understand the particular situation that you're running into - if you could show me an example model that would help me understand more specifically what you are trying to do.
< For example here I am rotating a box by using the rotation grip on the edit frame, notice how it rotates around its center:
And if you Click on the "rounded arraw" you can change the axe of rotation ;)
Ah, I didn't know that, cool! :)
And of course that works in 3D ;)
Show messages: All
1-13
14-18
