Full Version: Boolean issue II
Show messages: All  1-3  4-7
1 Feb 2010   [#4] In reply to [#1]
Do you have any of the original curves used for constructing this model?
If you can post them, it may help me to give some tips on some more robust construction techniques, like trying to build larger surfaces rather than a lot of little slivered pieces or some stuff like that.
Try to build some pieces larger than you need initially, with fillets applied for the rounded edges, then slice away excess material with a boolean, rather than going around trying to fill in one little patch at a time.
1 Feb 2010   [#5] In reply to [#1]
Hi Derek, here are some steps that would probably be easier for building a piece like this, working more with solids throughout rather than by going around filling in little patches.
To start with I drew a curve:
Then mirrored it and extruded it out into a solid block:
Now use Fillet to round off all the sharp edges:
Then prepare another curve, I used Construct > Offset to offset the original curve inwards a bit:
Then use Boolean Difference to cut the solid by the offset curve, to make a sharp inside cut, leaving the fillet around the outside to be rounded:
Things can tend to go more simply and quickly by working on a carving out pieces away from a solid like this. Hope this helps,
derek_step1.jpg  derek_step2.jpg  derek_step3.jpg  derek_step4.jpg  derek_step5.jpg
2 Feb 2010   [#6]
I just love these kinds of posts!
For me, that object type indicator is one of the most important features of v2 - I can tell at a glance if the object I have in hand is not a solid the way I expect it to be!
-Will
2 Feb 2010   [#7] In reply to [#5]
Michael,
I really feel appreciated for your quick answer. I fully understood what you say.
I was designing a mobile device case for my own. This is the part of it.
I go to a local CNC club meeting in Portland, OR.
Next time I go there I plan to demonstrate MOI.
Thanks again Michael. I'll probably be back to ask you for technical issue.
