Full Version: How to open v. Moi 2.0 beta file in Moi 1.1 ?
31 Jan 2010   [#1]
Hi
I modeled an object in Moi 2.0 beta and it´s now already expired.
Is it possible to get it open in 1.1 ?
anyway I exported the model just for rendering
into Cinema 4D and it is a test model.
Just curious.
31 Jan 2010   [#2] In reply to [#1]
hi there,
you should get the latest beta 2.0 from the download area.
http://moi3d.com/beta.htm
the current version will expire on 19 march 2010!
cheers,
marco
31 Jan 2010   [#3] In reply to [#1]
Hi kraphik3d, you just use the normal File > Open to open a MoI 2.0 beta file in MoI 1.1, there is nothing special you need to do.
MoI 1.1 can open the same files that MoI 2.0 writes, just some properties such as styles or object names will not be preserved into v1.1 since it did not support those things but the basic geometry will come in.
But also like Marco mentions above, the current v2 beta is still active and not expired. Double check your system date to make sure you have not altered the clock accidentally or something.
