Full Version: Trouble in design 3d!!!!!!!!!!!!!!!!!
Show messages: All  1  2-3
31 Jan 2010   [#2] In reply to [#1]
Hi aris, welcome to the world of 3d design!
Probably the best first step would be to view the video tutorials which are available here:
http://moi3d.com/1.0/docs/tutorials.htm
None of those are for specifically building a computer, but if you follow those tutorials they will teach you the basic elements of how you create 3D models in MoI. To build computer parts you will use the same techniques, just with different shaped curves and different shaped components booleaned together.
There are also some additional tutorial available here:
http://moi3d.com/wiki/Resources#Tutorials
Try several of those to get more familar with how MoI's tools work. The halogen lamp one is probably fairly close to something similar to a computer case.
If you get stuck on something and can't figure out how to make any progress, please post the 3DM model file of what you've got so far and try to explain what you are trying to do, and I will try to give you some suggestions.
1 Feb 2010   [#3] In reply to [#2]
Hi aris,
Welcome to the land of MoI.
If you are just starting in 3D then I would suggest doing some very simple models to start with. A computer is quite a complicated shape.
