Hi Michael and Moiers,
Just wondering if there is any script, or maybe workaround, to easily delete duclicated volumes that perfectly overlap each other.
I did a mistake in one of my scene (quite huge with more than 1000 solids), and somehow I copy/paste the all scene twice (Yes I know .... .. .).
Now, let's say you don't have any undo available (because I save/quit for example), is it any way to quickly delete duplicated volumes ?
I had to click/select one solid, hide it , then delete every copys,... really huge time consuming to clean the whole scene .
Stuff like that often append in poly modeling, but there are often command/scripts to juste clean the whole mess.
is for this case that a list of objects is usefull with hours dating !
Hi PaQ,
After Paste, don't unselect the objects and give them a different name.
You will find the name in the objectbrowser.
hi paq,
did you try the SelectParents-script?
http://kyticka.webzdarma.cz/3d/moi/#SelectParents
script:var gd = moi.geometryDatabase; var objs = gd.getSelectedObjects(); gd.deselectAll(); for ( var i = 0; i < objs.length; ++i ) { var parents = objs.item(i).getHistoryParents(); parents.setProperty( 'selected', true ); }
i duplicated a few solids on top of each other..selected the whole punch and ran the selectparents-script..ended up with just the "orginal" solids selected..
best of luck,
marco
Hi PaQ, I think Marco's idea of using history for selection is your best bet.
Right now there is not any general mechanism for detecting or removing duplicates.
