Full Version: New GPU Renderer - Octane
Show messages:  1-14  15-34  35-42
10 Jan 2010   [#15] In reply to [#13]
>Interesting link about Hypershot : http://develop3d.com/blog/2010/01/bunkspeed-the-future
how dishonest is that? I always thought HyperShot is the most over priced, rookies only piece of software....
11 Jan 2010   [#16]
Wow, looks nice! Good luck with this Philbo! I'm glad to see Radiance has been working on a commercial product. I had no idea this was under development. Also it's really well priced and perfectly timed with both the arrival of Thea and the questionable future of Hypershot.
My GTX280 is waiting to test this. One question i have, does this use only HDRI lighting? Or there is user-created lights as well?
jonah
EDIT - Just noticed it has emissive material properties, so that answers my question about lighting... :)
11 Jan 2010   [#17]
Hi Phil,
This looks promizing,
Are there any restriction with the .obj comming from MoI ? I mean, is it possible to use ngones ? Are the vertex normals fully translated ? Except Maya, .obj are really a problem with this ngone/normals stuffs, whatever you use 3dsmax, modo or lightwave ... without talking about uv's limitation too (only one channel).
Are you planning to extend the files support ? (true .3dm import with tesselation on the fly, .lwo, .fbx) ?
I'm also really curious to see more complex indirect lighting scenario, and how long it takes to render to clean the noise.
As a final note, there is something a little bit strange with the textures from actual examples provided ... I'm not a technical guy, but they looks really blured/washed/compressed ... there is this kind of realtime texture feeling about it, maybe it's the filtering I don't know. (I know it's still in alpha)
11 Jan 2010   [#18] In reply to [#16]
What is a CUDA card. I have a MacBookPro. Does it have a CUDA card.
Rudl
11 Jan 2010   [#19]
CUDA-Enabled Products: http://www.nvidia.com/object/cuda_learn_products.html
11 Jan 2010   [#20] In reply to [#18]
I also have MacBookPro with 9600M GT (CUDA-enabled)... BUT that card could only render TEAPOTS :) if you know what I mean.
11 Jan 2010   [#21] In reply to [#20]
Well I also have MacBookPro with a 9600M GT and its already faster than Quad core at 2.4ghz (Q6600)
According to this graph
http://www.refractivesoftware.com/forum/viewtopic.php?p=1150#p1150
That mean you can render like 4 time the ammount of teapots in the same ammount of time !!!
11 Jan 2010   [#22]
My MacBookPro is a little bit older and has only the 8600M GT in it.
Is it worth to give this renderer a try.
Rudl
11 Jan 2010   [#23]
12 Jan 2010   [#24]
I just purchased my CUDA enabled card and will be purchasing Octane as soon as the but up the link.
On a side note, maybe MoI could get CUDA enabled? This may allow us poor linux users to enjoy MoI in a VM, or better yet, natively. I am sure it would be much easier than porting to OpenGL..? I purchased MoI v1.0 way back and honestly just through my money away, as I have only used it a couple times at work (when I was supposed to be working - I don't run Windows at home).
12 Jan 2010   [#25]
An Octane viewport inside MoI would be terrific ... (sorry, so thinking loud)
... I'm half sold (well completely in fact, at 100Euro I can't be wrong) ... just this memory limitation is a bit annoying. Today 'render' station have easilly 8 or 12 Mo (I'm on 16Mo here, and I allready feel limited sometimes). I'm not really sure nvidia will put so much memory on a gaming card any soon ... the biggest available are 'only' 2Mo (and it's allready a waste of memory for actual games requirement)
12 Jan 2010   [#26] In reply to [#25]
PaQ it will support multiple cards so 4 cards at 1gb will be like one card at 4gb
Also 2gb cards are coming soon (mainstream prices)
12 Jan 2010   [#27] In reply to [#26]
Yes I know for the 2gig card ... but having 4 of them dont give you 8 gig, as the card can't share memory ... one copy of the scene data will be stored per GPU to speed up the rendering. (I allready asked on the Octane forum ;))
12 Jan 2010   [#28] In reply to [#25]
Should be the other way around. :o
12 Jan 2010   [#29] In reply to [#24]
Hi Phr0stByte,
What part of MoI would you expect to use CUDA?
I'm not sure if CUDA is what you are expecting - it's a mechanism for giving programming access to the resources of your GPU for certain kinds of calculations.
It's most useful for something that can be broken up into something like a million little smaller tasks that can be run in parallel (similar to rendering).
It is not generally very feasible to use CUDA for the regular real-time viewport display of a modeler, which is what you seem to be thinking of? I mean it is possible, but it would mean writing a lot of custom code to just reproduce what is already set up in Direct3D or OpenGL.
Nope - it would be more like 100 times more work than porting to OpenGL, because I'd basically be trying to rewrite what OpenGL does.
12 Jan 2010   [#30] In reply to [#24]
Actually this may already be possible - there are several Mac users that run MoI in a VM on Mac OSX using Parallels or VMWare.
I think that VMWare is also available for Linux so you can try that.
Actually, you can already do that as well at least for basic stuff by using WINE.
You do have to set up IE6 or IE7 under wine though, look for something like "wine tricks" to find out how to get IE installed and then you can actually launch MoI running the code directly in WINE. Not everything works, like a couple of little menus don't show up but for the most part it appears to be ok:
http://appdb.winehq.org/objectManager.php?sClass=version&iId=7383
12 Jan 2010   [#31] In reply to [#30]
Paq >>>> but having 4 of them dont give you 8 gig, as the card can't share memory
Ok. That's bad but not so much because 4gb cards are coming soon :)
12 Jan 2010   [#32]
Michael, could MoI use CUDA to speed up slow operations -- like booleans?
12 Jan 2010   [#33] In reply to [#29]
3D Coat has an option for Cuda, and combined with DX, operation in both 32 and 64 bit versions.
The speed up of calculating is excellent.
Brian
12 Jan 2010   [#34] In reply to [#32]
Hi anthony,
No, it's not really feasible to do that - things that are suited for CUDA are more when you have a very large quantity of somewhat more simple individual tasks.
Booleans don't particularly fit into that category - although it would be theoretically possible (with quite a lot of work to rewrite some chunks of the geometry library) to separate booleans into some list of individual tasks, each of those tasks is fairly complex and involves the intersection between 2 NURBS surfaces.
It's not easy to make more complex individual functions run on the GPU, and it is also not very easy to take existing program code and automatically turn it into CUDA, the GPU is a fairly different environment for processing things than the CPU and you cannot just push a button and automatically run the same kind of process on it.
See here for some information: http://en.wikipedia.org/wiki/CUDA#Limitations
It wasn't even too many years ago that shader programs on GPU did not even have any branching (like if/then) instructions available to them...
I can't really think of any particular area of MoI that would fit into the massive parallel processing of more simple individual calculations that would fit well with CUDA. In general the things that MoI does have more potential for multi-core CPU processing, and there has been a big step forward with that already in MoI v2 with the mesh generation at export making use of multiple CPU cores.
