Full Version: Trouble with Fillets
Show messages:  1-4  5-24  25-35
9 Nov 2008   [#5] In reply to [#4]
John, Michael has the answers.
For interest, here is a rough (very) render of my approach.
Brian
9 Nov 2008   [#6] In reply to [#1]
Hi John, another kind of technique that can work pretty well for this stuff is kind of along the lines of what Brian wrote previously.
But instead of trying to build a fully curved piece all in one surface what you focus on is in curving one area only and leaving the other side to be filleted.
Here's an example:
Model is attached as guitar_loft_fillet.3dm
What I did in this case was take 4 curves, and then Loft a surface through them, using the Loft Style: Loose option, which tends to reduce the bulgy-ness of the lofted result.
That has kind of built in the curvature of the lower part of the body directly into the surface.
But then I let it come to a sharp edge at the top, when then can be filleted.
This can be a generally good strategy to use - to leave a fillet for finishing off kind of the end of a shape but trying to use surfacing tools to handle the shaping of the interior parts rather than trying to use filleting for the sort of internal pieces of the shape...
9 Nov 2008   [#7] In reply to [#6]
I never hit on the method Michaels going to produce ....Novice!
I started off fooling with blend (A recent forum favorite) and after seeing Michaels realize that although mine "looks" ok it is not the original shape as I thought.
Let the studies continue.
9 Nov 2008   [#8]
Woah, thanks for the replys guys, this was fast. I thank you all for helping and offering your advice with this.
Michael, I now understand what you mean about the fillets. I just assumed it would work similar to loops in polygon models (how wrong was I?) I think your first method is what I am looking for. Do you think it's possible for me to "fake" the second lines fillet by using a loft? or would it be possible for me to fillet in certains areas where the surface doesn't go flat?
The second method also looks interesting, and I think I will put it to use on other objects needed for the full guitar. Thanks again.
Burrman, I actually like the result. The outer edges are nice and smooth, it's just the inner sections by the neck that bother me. Would you mind showing how you did it? I can't seem to get anything out of blend.
9 Nov 2008   [#9] In reply to [#8]
John,
Yeah, your actually right in that with the blend method and a default value of "1" for a G1 the part where the body meets the top of the neck gets all pinched up, so the result you see here or in my previous post is not what you would acheive, I got a smooth transition with a ".5" G1 but its a drammatically different level of smoothness for the edges.
Possibly redrawing the top curve to be much smaller can produce a different result with blend but I have to say I took Michaels model through to a solid and it actually looks like a guitar! I'll poke around a bit more and If I get anything substantial with blend I'll post back. Have fun!
Burr
9 Nov 2008   [#10] In reply to [#9]
I'll stop here as I'll only get nuts now.
If you're being creative then the blend can produce some cool stuff...(the latest alembic?)
If you need to be precise, I must defer to the master with the loft loose example.
9 Nov 2008   [#11] In reply to [#10]
The last example provided is almost perfect, just a little highly raised. You pretty much nailed it spot on. Thanks again.
9 Nov 2008   [#12] In reply to [#8]
Hi John,
:) Yup, it is pretty different. Fillets actually do quite a large number of calculations, including making offset surfaces (surfaces that are a constant distance away from the existing ones), and calculating the curves of intersection between 2 surfaces. Then comes some other stuff like creating fillet surfaces that follow those intersection curves, and then doing some additional extensions and intersections between the fillet surfaces and finally filling in corner pieces where different fillet pieces might meet.
Since there are a lot more complex calculations involved, there are also a lot more things that can go wrong than just pushing points around in edge loops... But the upshot is that the final result is a very accurate piece that has a cross-section of an exact circle.
You tend to get the best results if you have pretty "clean" geometry.
> loft?
It would probably be difficult to get good results by doing that. You could put in a "fake" piece with a loft definitely, but it will probably look pretty fake as well because is difficult to produce a smooth result with that method. The loft that you generate will not be ensured to be smooth with the adjacent surfaces. That's another big difference between working with NURBS and working with sub-d polygons - with your NURBS constructions just building 2 different surfaces adjacent to one another with any particular tool does not guarantee that they are smooth to one another. But there are a couple of particular tools like Fillet and Blend that you can use that are set up to build a result that is smooth to adjacent pieces.
The other way that you generally ensure smoothness is to build your model in larger sheets instead of in small pieces or strips when possible. You can pretty easily guarantee smoothness of a single surface construction, like one loft will be smooth inside its own generated result as long as your input curves are also smooth.
So it can help if you build what should be a smooth section as a larger surface sheet instead of trying to do it in diced up bits.
When I saw your result that had 2 surfaces that were both flat, it made me think of building one single larger surface sheet (with that loft method) there instead of that.
But just a note - it is also possible to go too far in the other direction and try to build too much out of a single surface as well. Each "larger sheet" should be a kind of logical component of the model, it can also cause problems trying to build a model made up of many different shapes out of only one single surface as well..
That's probably possible but you would likely need to dice up the model into different pieces to make that happen.
9 Nov 2008   [#13] In reply to [#10]
Hi Burr,
Well, loose loft is not necessarily any more precise, just a different way...
There is often more than one possible route to get a good result! :)
9 Nov 2008   [#14] In reply to [#9]
Burr, so that's what you sound like :) cool tute dude. Camtasia??
10 Nov 2008   [#15] In reply to [#14]
I found that a person never sounds like what I had imagined! I wonder what I used to sound like to you??? He he!
(Since I used other space I could add the audio without worry of size. For me it helps with the understanding of whats happening on screen and the thought process of the creator!)
Yes that was Camtasia. I have another one called captivate which is a pretty powerful tool but not as down and dirty as camtasia. It needs more massaging after the fact. So for a quick record and post its camtasia. Actually If I didnt already have the camtasia loaded I would just use Jing.
10 Nov 2008   [#16] In reply to [#15]
Oh Billy!!!!
11 Nov 2008   [#17]
Being a guitar player myself, this thread is well respected!
-Will
11 Nov 2008   [#18]
Hi all,
Maybe this one could also find your interest ...
11 Nov 2008   [#19] In reply to [#18]
Hi Matthew, that one looks great! A lot of details in there, even the little twisted parts at the very ends of the strings wrapped around the pegs, cool!
11 Nov 2008   [#20]
Wow, nice guitar. Very detailed job. Hope we will see some nice render.
11 Nov 2008   [#21] In reply to [#18]
Nice one Matthew, good job, love the details!
11 Nov 2008   [#22]
here is a rendered image, hope i will find the time to make some additional views ...
Must admit, the three lower Strings are not wound ;-)
13 Nov 2008   [#23]
Hey, I thought after doing the "test" guitar I could move on, and whilst I did get a better understanding in Moi from you guys, I am about to attempt this and struggling to see how I can create it. I've tried several methods in this thread, but I'm getting bad results. Mostly these "arch" shapes, along with the filleting of it.
I've included my shapes, along with a reference. It's seriously driving me crazy, as I personally have this guitar and want to recreate it in 3d.
002.3dm
13 Nov 2008   [#24] In reply to [#23]
Hi John, MoI's filleter is not really going to be able to handle those spots where you've got surfaces that are partially tangent to one another but then further along come to a crease.
For MoI's filleter to work those surfaces are going to need to meet at more of an angle to one another throughout their entire common edge.
Here is one of those spots that I'm talking about:
In this version, I have adjusted the top shape inward slightly to avoid that situation and make a more continuous crease along the shared edges between the surfaces:
This version can now be filleted throughout (using v2 beta Sep-21 version):
Result 3dm model is attached as 002_filleted_3dm.zip .
If you don't want to shrink the upper profile down at all, then that shape is just not going to be possible to fillet in MoI (at least not for some time to come anyway). You could try some other NURBS programs that have more advanced filleting than MoI such as SolidWorks, or you could also try switching to a more "low level" surfacing approach where you work on constructing surfaces more individually rather than using the solid modeling tools. That would be like building in some of the fillet surfaces by doing things like sweeping them, rather than using the solid modeling tools. But that tends to take a lot more time.
