14-23
OK it did--all have fun.
Brian
This is a rewritten version of the original Spur Gear script
This Script has excellent examples of how to code for multiple factories, in htm, if I can understand them.
I see that the function factory(factoryname) is being passed more (parameter) arguments than are declared.
The "argument object "is being used to process the arguments.
http://www.w3schools.com/js/js_function_parameters.asp
The techniques of this script are perfect for a polyskelions script, because I need 2 interpcurve factories.
I've got the two curves coded up already.
The join and circular array will come in handy also. And sliders.
Hi Brian
This factory function trick I found in the old SpurGear script. :)
Unfortunatelly, I can't find the original thread and the author name of this script.
Hi Max,
Could you please explain what the re-written spur gear script does?
See post #3 re Petr ?
I've been looking for a formula for internal spur gears...with ambiguous results so far.
I saw the factory function somewhere else awhile back.
OnClick is used again.
Just found this gear generator that might be useful to someone? http://geargenerator.com
BW
Keith
Thanks a lot Keith!
Very useful.
Ciao!
Interesting! Thanks! : - )
Hello, I made an update to the gear script.
It adds a checkbox for planetary gears, and creates properly-meshing ring-gear.
Simply
Addendum and
Dedendum values are switched.
Gear.v1.1.2021.03.22.zip
14-23
