Full Version: Reverse Flow
Show messages: All  1-5  6
9 Nov   [#6] In reply to [#4]
Hi Raven,
> Can I take a curved solid and make it flat?
In some cases yes, in some cases no. It would help to be more specific if you could post an example object.
If all you have is the final result solid and none of the deformation inputs you may need to sort of reverse engineer those. That can range from easy to difficult depending on the specifics.
Also if you have something like a sheet metal part that has a lot of localized bends that's a lot different than just one single deformation for the entire solid.
