Show messages: All
1-2
3-6
Hi Raven,
> I guess what I'm saying is; can a 3d solid be unwrapped or
> projected back to its original simpler form?
Do you have any example objects?
...another way to say it is this:
Can I take a curved solid and make it flat?
<< Can I take a curved solid and make it flat?
Of course yes!
Use Flow again ;)
Here i use the Flat Line so has easily the middle start curve!
Make the curvated volume by extrude
Draw any staight Line as target withany measure...
(if you want to know for any reason the result of the exact lenght before use the Flow function use the UnWrap curve
https://moi3d.com/forum/messages.php?webtag=MOI&msg=5136.1
Or use the Button Detail of the selected curve! :)
Make the Flow
Et voilĂ you obtain your Unflow volume Curvated to "Flat" !
Hi Raven,
In some cases yes, in some cases no. It would help to be more specific if you could post an example object.
If all you have is the final result solid and none of the deformation inputs you may need to sort of reverse engineer those. That can range from easy to difficult depending on the specifics.
Also if you have something like a sheet metal part that has a lot of localized bends that's a lot different than just one single deformation for the entire solid.
Show messages: All
1-2
3-6
