Show messages: All
1-2
3-15
Good day.
I tried a few settings and getting close...but not exactly..
I am guessing the only way is try to recreate it in Blender and or Nvil3d and send back to Moi3d..now I am looking more into it seems polynurbs is used to get the smooth result am looking for.
but I do not know any decently priced app to do this...
Tnx!
Thanks for the link, Michael.
I use Quad Remesher from time to time and I’m quite happy with it, although it does produce, erm, surprising results depending on the object you’re trying to retopologise.
Hi Matadem,
The attached OBJ file is similar to a pipe structure. You can use your topology optimization results as a reference to generate helper curves to serve as pipe rails, then use the "MultiPipe2" command. You can also use different styles to set various pipe radii.
If you plan to create more complex objects like those in the video, you will need to retopologize your object, which can be challenging. While there are various plugins for automatic retopology, I haven't tried all of them. Here are a few tips that may help with an auto-retopology workflow:
1- Make the object symmetrical to achieve cleaner results more quickly.
2- Use a denser mesh for retopologizing, your object file was too low poly. In my experience, results are better on slightly denser meshes—though not excessively so. For your object, I first used the "Remesh" modifier to make it slightly denser and then processed it with the "QRemeshify" plugin. (Any other auto remesher will do)
Attached the multipipe result and remeshed object (not perfect).
MultiPipe Command:
https://moi3d.com/forum/messages.php?webtag=MOI&msg=12116.6
QRemeshify:
https://ksami.gumroad.com/l/QRemeshify
p.s
It has been a long time since I last updated this plugin. I realized it's been two years since the last update, so it might not be compatible with newer versions of Blender.
opt1obj_MultiPipe.obj
opt1obj_Re1.obj
I managed to make something in Blender, Nvil and Moi.
so my best bet is to take the image of the result and remake it.
The multipipe worked great!
Hi MO,
Thank you for your informations and suggestions.
QRemeshify 1.1.0 is compatible with the latest version of Blender 5.2.2 LTS
Kind regards
@ Zooen
Cool, Thanks!
Hello, could be easier if you could get a bit more definition (voxels) in that source mesh tho ... 10 iteration of quad remesh > smooth push > blur
Hou 22.0
opt1obj.FBX
opt1obj.hip
@ PaQ
That looks pretty smooth..
what is the process?...I rarely use blender ...just for 2 add ons.
Tnx!
Hi Matadem,
In this case, Paq used Houdini 22.0. Houdini is very powerful for retopology.
- Zooen
Yes it's houdini here (the .hip is include), but the general ideal is to run the quad remesher multiple time. Houdini QR is not as good as Exoside one, but it's super fast, so you can chain process it.
The loop is quad remesh > computing normals > average the normals (blur) > pushing the point along normal (small distance) > blur the result > repeat.
It's pretty close the the erode>blur filtering usually used to smooth out liquid from simulation ... that said it was just a guess to solve this here, not sure that method is robust enough whatever the mesh you throw at it.
I suggest you the free TopMod who can make this sort of thing!
https://moiscript.weebly.com/topmod.html
A killer one: never seen so easy and powerful prog! :)
So seems to me that your form above will be a game boy for it! :)
To obtain the kind of organic, openwork structure typical of TopMod from your base quadrilateral mesh, follow these steps to continue your modeling process:
1. Apply a preliminary subdivision (Doo-Sabin)
Before hollowing out the form, it is common to apply an initial round of subdivision to restructure the geometry:
Apply one iteration of the Doo-Sabin algorithm. Unlike Catmull-Clark, Doo-Sabin gives quadrilaterals a more mathematical and structured appearance, which serves as an excellent foundation for this type of sculpture.
2. Use Rind Modeling (Hollowing and shell creation)
This is the core function in TopMod, which allows you to transform a solid volume into a mesh-like or perforated tubular structure (as seen in your image):
Select the loops of quadrilateral faces that you wish to transform or remove.
Apply the Rind Modeling function. This command converts your mesh into a thin, hollow shell while opening up and piercing the corresponding areas.
3. Smoothing and finishing (Catmull-Clark)
Once the openwork shell has been generated, the edges may appear a bit too rigid:
Apply one or more iterations of the Catmull-Clark algorithm (or Doo-Sabin again) to smooth the edges, round out the junctions, and achieve that fluid, organic, 3D-sculpted look.
By experimenting with your initial selection of quadrilateral loops before activating Rind Modeling, you can freely adjust the size, thickness, and shape of the openings.
@Matadem ... Altar clearly use a quad remesher to convert the low res voxel model form material reduction into a smooth surface.
Blendtopo can generate a bit more voxels tho, (Final resolution ? maybe the poisson feature), I'm not sure how slow the process is, but pushing the resolution will help the remesh a lot.
I use to think exoside quad remesher was the best for the job, but in your case maybe one of those AI remesh could work better. The AI shape guessing might output a smoother low quad cage, that you can then convert to Nurbs in MoI.
https://studio.tripo3d.ai/workspace/retopology
Not that bad (according how coarse the source is) ... those AI web services are unbearable tho, pop up everywhere, any settings change need credits ... it's about time people fight back to run those stuff locally.
Show messages: All
1-2
3-15
