4-23
24-42
Hi Mala,
> This the list of scripts I found and put into the command folder.
It should be "commands" (note "s" at the end), not command.
You need to put the contents of all those folders into the commands folder.
Most of those will have 2 files, one with a .js file extension and one with .htm file extension. Those 2 files need to get copied into the appdata commands folder. Directly into that folder, not into a child folder like you currently have.
All available scripts - how to pick?
I have the feeling that the scripts in the screenshot aren't all the ones available.
I looked at
Max Sirnos´s Script Archive:
https://moi3d.com/wiki/MaxScriptArchive
At resources page:
https://moi3d.com/resources
Petr´s MoI Page:
https://moi3d.com/download/scripts/PetrsMoiPage/PetrsMoiPage.htm
Pilou:
https://moi3d.com/wiki/PiesMenuForMoi3D
How to get all available?
Mala
P.S.:
ok - just found BurrMan´s
https://moi3d.com/forum/index.php?webtag=MOI&msg=7841.6
https://moiscript.weebly.com/
You mean the scripts should be placed there: Win-key + R:
%AppData%\Moi\commands
When I do that this path is opened on my Win11:
C:\Users\info\AppData\Roaming\Moi\commands
Something is wrong. No MoI folder in AppData.
In the folder "Roaming" - there is a MoI folder. Idea why?
Mala
Hi Mala, Burr's archive is listed on the resources page:
The link is named "Burr's script archive - collection of scripts posted on the forum".
Hi Mala,
Yes, as described in the
FAQ question #1
quote:
On Windows you can find the Moi appdata folder by typing Win+R to bring up the Windows "Run" dialog and then type in:
Yes, that's where you need to put them.
Nothing is wrong, it is normal that the MoI folder is located under C:\Users\info\AppData\Roaming\ and not C:\Users\info\AppData\ .
The reason why is that there are 3 different ways in Windows to store user profile data. Just C:\Users\info\AppData\ is not intended by Windows to have data stored in an immediate sub folder, it is supposed to go inside AppData\Local , AppData\LocalLow or AppData\Roaming, depending on the type of data. The most commonly used and the one used by Moi is under AppData\Roaming.
If you want to know the details on the different types of user profile data there is some info on it here:
https://www.thewindowsclub.com/local-localnow-roaming-folders-windows-10
got a 404
As you can probably tell, I’m no expert when it comes to PC file structures and systems. I just want to know where the files are supposed to go. I’ve now copied in all the scripts I found, but I still can’t launch them. They ought to be in the right place by now—under C:\Users\info\AppData\Roaming\Moi\commands.
Do the file folders perhaps need to be unzipped:
Hi Mala,
> got a 404
Sorry I had a typo, it's fixed now:
Hi Mala,
The answer is in the first 2 sentences of the FAQ, please read it:
FAQ #1, How to install a plug-in script.
Also it can be helpful if you change a Windows setting so it will not hide the file extensions:
https://www.howtogeek.com/205086/beginner-how-to-make-windows-show-file-extensions/
Message 12126.13 was deleted
Hi Michael, thanks—I don't think I have issues with the file extensions; I can see whether a file is .html or .js.
New - I moved the HTML/JS files from the folders into the commands folder, but I'm still having problems. When I launch MoI, I get the error message I’ve attached, and I still can't run the scripts within the program.
Message 12126.15 was deleted
Thanks, Zooen, for your efforts. However, I fail to see what the organization of the displayed file structure has to do with the fact that the script folder (or "commands" folder) cannot be launched from within MoI. Are we—or rather, am I—talking at cross-purposes?
Hi Mala,
You will get that error message on the program startup if you have placed the _Voronoi.js file in the %AppData%\Moi\
startup folder.
It is not intended to be used as a startup script, it is meant to be copied into the commands folder.
If you delete the _Voronoi.js file from the startup folder that error message should stop being shown on program startup.
If you have got _Voronoi.js and _Voronoi.htm copied into the commands folder, how are you trying to run the scripts?
Hi Michael, Voroni - Iremoved it > no more error message. Thank you.
A problem persists, however: when I click on "Scripts" in the bottom bar, the scripts in "Commands" are not triggered. Also, the "Scripts" entry appears twice.
Hi Mala,
When you say "not triggered" do you mean they are displayed but don't do anything when you pick one in the menu?
Or do you mean they are not displayed in the scripts menu at all?
If you look the %AppData%\Moi\startup folder, do you have 2 files there named something like "80 Scripts.js", and "81 Scripts Full.js" ?
If so then delete one of them so you won't have 2 scripts buttons on the bottom bar.
I think the "full" one also displays all regular built-in commands as well.
Thanks Michael, I removed "80 scripts" > it now appears only once in the GUI. However, just like the "Light" script, it doesn't open scripts from the "Commands" folder; a small black-and-white area just keeps appearing instead.
What is still wrong there?
Mala
...here are the data folders: commands / plugins / startup / themes
Are the HTML/JS files incorrectly located?
Mala
Are the HTML/JS files assigned incorrectly?
Mala
P.S.: Plugins and themes are empty.
Message 12126.22 was deleted
That’s strange (though I might be way off the mark!) – you don’t have a ‘customui’ folder in the ‘Moi’ folder
AppData > Roaming > Moi > customui
My ‘customui’ folder contains
Scripts.menu.htm
ScriptsFull.menu.htm
LightingOptions.htm
LightingPresets.menu.htm
I’ve just carried out a test: if I disable LightingOptions.htm and LightingPresets.menu.htm, I get the same empty rectangles as you.
That might be a lead – and I do mean might.
4-23
24-42
