5-24
25-42
Hi Zooen, thanks for the effort; I’m going to uninstall and reinstall MoI now. If that doesn’t work, I might be able to create the `custommoi` folder manually.
P.S.: Just´ saw michaels workaround, thank you, and try this as second option like intended by me too.
Hi Mala, uninstall/reinstall MoI isn't going to do anything for this particular problem, the stuff that you need is from a UI mod and isn't part of the regular install.
If you make a folder customui at the same level as commands/startup/etc... and copy the above files into it that should get the UI mod set up.
Hi Mala,
Yes you should create the folder manually, but note that it should be named customui , not custommoi .
Hi MALA,
I might be wrong since I'm going off a day-old screenshot, but I think you accidentally extracted "CustomUI.2.0.beta2" into your "Commands" folder. You can see it in your screenshot in post #10.
The contents of that folder should actually go into "AppData/Roaming/Moi", As Michael and Zooen mentioned.
Hi Mo,thx.
I added "CustomUI.2'" - still does not run. (also with Michael hints not)
Mala
You should open the "CustomUI.2.0.beta2" folder and copy all the folders inside it, then paste them into "AppData/Roaming/Moi". It looks like you copied the main folder instead of its contents.
I tried to follow your ideas - still no commands open by click "scripts" button in MoI-GUI.
Other thoughts - the file structure within the `AppData>Roaming>Moi` path now includes the `CustomUI2` folder—just like with Mo. This folder, in turn, contains the `customui`, `objects`, and `startup` folders. However, there is no `commands` folder. That strikes me as odd and is confusing; it’s like a parallel file structure that is almost identical.
Also, Michael, you mentioned that `CustomUI2` should go into the `AppData` folder (at least, I think I read that—though I can't seem to find it in the thread anymore)(or is this a misunderstanding from my side - almost little confused).
Any thoughts on these points, questions, or observations?
@ Mala,
That's because you haven't copied the contents of the "CustomUI.2.0.beta2" folder yet. You need to copy the "customui", "objects", and "startup" folders into the 'moi' folder. Select "Replace" if Windows asks.
The 'moi' folder structure should look like this:
Moi
├── commands
├── customui
├── objects
└── startup
Other files and folders stay the same.
The commands downloaded from the forum or website (those consisting of .js and .htm files) should be placed directly in the 'commands' folder. Do not place them inside any subfolders; move only the files themselves.
Thanks a lot, MO, for really digging into this. I’m so confused—I can’t make heads or tails of it anymore. Is there no documentation or how-to guide for the overall structure—and which files go where? Or did you all just get it right instinctively?
No problem; it looks like you just mixed up the installation process for the commands and the custom UI.
It seems you've already installed your commands, so just go for fixing the custom ui. I'll put the links in case you need them.
To install commands, follow the guide here:
https://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
For example, the edgeFlange.js and edgeFlange.htm files should go directly into the "commands" folder.
To install the custom UI, follow this instruction:
https://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
Take your time and try again. You'll see it's quite simple once you get the hang of it.
Hi Mala,
I will attempt to help with my observation.
I think the error for you comes from extracting "Zipped" or "compressed archives"
I have created a sample file for you to test with. A Zip file which contains only 1 single, text document named "1.txt"
You can test HOW you are extracting the contents of the file!
There are usually "2 ways" that the extraction happens. Your choice matters.
in Winzip or Winrar, the options are these:
1. Extract Files
2. Extract to 1
3. Extract Here
The first 2 methods create a folder named the same as the contents, with the contents inside that. So a folder named "1" appears, with the 1.txt file inside of that.
The last method, #3, Extracts the Contents (a single "1.txt" file) to where you chose
So with this file, experiment with how you extract it and realize when and where you get the "contents" of the zipped archive! A single text file.
With most of plugins. the "contents" are usually a js file and an htm file.
With things like customui, make sure the folder extracted is the "contents" and not a folder named as the zip.
Hope this helps
1.zip
And here is one more to add to your testing:
a zip file named "Mala's Archive created for testing1"
In this zip file is a folder named 1
In the "folder named 1" is a text file named "1.txt"
Practice to get a folder named 1, with a single text file inside of it.
Mala's Archive created for testing1.zip
Hi Mala,
LightingOptions.htm
LightingPresets.menu.htm
LogScroll.htm
ObjLibrary.cfg.htm
ObjLibrary.menu.htm
Scripts.menu.htm
ScriptsFull.menu.htm
Shortcuts.menu.htm
Hi Mala,
The message is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=12126.24
What I wrote was:
quote:
Make a folder named customui at the same level as commands/plugins/startup/themes and put the attached files into it.
Hello,
I have now remapped and set up the structure as last specified - thank you Michael/All.
What is missing now is the other GUI with the ribbon at the bottom. This is presumably because I deleted the CustomUI.2.0.beta2 script?!
Hi Mala,
The other GUI is created by files in the startup folder.
If those are missing it means you accidentally deleted the startup folder, is it empty now?
To set it up again you need to copy the files from the startup folder inside CustomUI.2.0.beta2.zip into %AppData%\Moi\startup .
Maybe it would be better for you to contact me through e-mail to help you get set up instead of here on the forum. It will probably be easier if we do things just one small step at a time.
My e-mail is:
moi@moi3d.com
Wow—that actually worked. Thanks a lot!!! What a ride! I need to let it all sink in now and see where I might have missed something in the installation instructions. I’m sorry for having put your patience to such an extreme test. I hope I won’t be draining your energy again for a good few years ;-)—this whole thing was a massive undertaking... Best, cheers, Mala
In one of your previous messages you showed what your startup folder had in it which was correct:
5-24
25-42
