16-35
36-42
Thanks, Zooen, for your efforts. However, I fail to see what the organization of the displayed file structure has to do with the fact that the script folder (or "commands" folder) cannot be launched from within MoI. Are we—or rather, am I—talking at cross-purposes?
Hi Mala,
> When I launch MoI, I get the error message I’ve attached, and I still
> can't run the scripts within the program.
You will get that error message on the program startup if you have placed the _Voronoi.js file in the %AppData%\Moi\
startup folder.
It is not intended to be used as a startup script, it is meant to be copied into the commands folder.
If you delete the _Voronoi.js file from the startup folder that error message should stop being shown on program startup.
If you have got _Voronoi.js and _Voronoi.htm copied into the commands folder, how are you trying to run the scripts?
Hi Michael, Voroni - Iremoved it > no more error message. Thank you.
A problem persists, however: when I click on "Scripts" in the bottom bar, the scripts in "Commands" are not triggered. Also, the "Scripts" entry appears twice.
Hi Mala,
When you say "not triggered" do you mean they are displayed but don't do anything when you pick one in the menu?
Or do you mean they are not displayed in the scripts menu at all?
If you look the %AppData%\Moi\startup folder, do you have 2 files there named something like "80 Scripts.js", and "81 Scripts Full.js" ?
If so then delete one of them so you won't have 2 scripts buttons on the bottom bar.
I think the "full" one also displays all regular built-in commands as well.
Thanks Michael, I removed "80 scripts" > it now appears only once in the GUI. However, just like the "Light" script, it doesn't open scripts from the "Commands" folder; a small black-and-white area just keeps appearing instead.
What is still wrong there?
Mala
...here are the data folders: commands / plugins / startup / themes
Are the HTML/JS files incorrectly located?
Mala
Are the HTML/JS files assigned incorrectly?
Mala
P.S.: Plugins and themes are empty.
Message 12126.22 was deleted
That’s strange (though I might be way off the mark!) – you don’t have a ‘customui’ folder in the ‘Moi’ folder
AppData > Roaming > Moi > customui
My ‘customui’ folder contains
Scripts.menu.htm
ScriptsFull.menu.htm
LightingOptions.htm
LightingPresets.menu.htm
I’ve just carried out a test: if I disable LightingOptions.htm and LightingPresets.menu.htm, I get the same empty rectangles as you.
That might be a lead – and I do mean might.
Hi Mala,
Those are located correctly now.
I think Zooen is correct that you're missing part of the CustomUI mod that adds those buttons to the bottom toolbar.
Make a folder named customui at the same level as commands/plugins/startup/themes and put the attached files into it.
For the lighting menu to work you will need to run the Lighting Options dialog one time. To do that select the following text and do Ctrl+C, then inside MoI type the Tab key to put keyboard focus into the XYZ input box in the bottom toolbar and then Ctrl+V then Enter. The lighting options dialog should show, and that will initialize the lighting options stored in moi.ini and the lighting menu should then work.
Text to paste is this:
script: /* Opens Lighting Options Dialog */ moi.ui.createDialog( 'moi://appdata/customui/LightingOptions.htm' );
LightingOptions.htm
LogScroll.htm
ObjLibrary.cfg.htm
ObjLibrary.menu.htm
Scripts.menu.htm
Shortcuts.menu.htm
Hi Zooen, thanks for the effort; I’m going to uninstall and reinstall MoI now. If that doesn’t work, I might be able to create the `custommoi` folder manually.
P.S.: Just´ saw michaels workaround, thank you, and try this as second option like intended by me too.
Hi Mala, uninstall/reinstall MoI isn't going to do anything for this particular problem, the stuff that you need is from a UI mod and isn't part of the regular install.
If you make a folder customui at the same level as commands/startup/etc... and copy the above files into it that should get the UI mod set up.
Hi Mala,
Yes you should create the folder manually, but note that it should be named customui , not custommoi .
Hi MALA,
I might be wrong since I'm going off a day-old screenshot, but I think you accidentally extracted "CustomUI.2.0.beta2" into your "Commands" folder. You can see it in your screenshot in post #10.
The contents of that folder should actually go into "AppData/Roaming/Moi", As Michael and Zooen mentioned.
Hi Mo,thx.
I added "CustomUI.2'" - still does not run. (also with Michael hints not)
Mala
You should open the "CustomUI.2.0.beta2" folder and copy all the folders inside it, then paste them into "AppData/Roaming/Moi". It looks like you copied the main folder instead of its contents.
I tried to follow your ideas - still no commands open by click "scripts" button in MoI-GUI.
Other thoughts - the file structure within the `AppData>Roaming>Moi` path now includes the `CustomUI2` folder—just like with Mo. This folder, in turn, contains the `customui`, `objects`, and `startup` folders. However, there is no `commands` folder. That strikes me as odd and is confusing; it’s like a parallel file structure that is almost identical.
Also, Michael, you mentioned that `CustomUI2` should go into the `AppData` folder (at least, I think I read that—though I can't seem to find it in the thread anymore)(or is this a misunderstanding from my side - almost little confused).
Any thoughts on these points, questions, or observations?
@ Mala,
That's because you haven't copied the contents of the "CustomUI.2.0.beta2" folder yet. You need to copy the "customui", "objects", and "startup" folders into the 'moi' folder. Select "Replace" if Windows asks.
The 'moi' folder structure should look like this:
Moi
├── commands
├── customui
├── objects
└── startup
Other files and folders stay the same.
The commands downloaded from the forum or website (those consisting of .js and .htm files) should be placed directly in the 'commands' folder. Do not place them inside any subfolders; move only the files themselves.
Thanks a lot, MO, for really digging into this. I’m so confused—I can’t make heads or tails of it anymore. Is there no documentation or how-to guide for the overall structure—and which files go where? Or did you all just get it right instinctively?
No problem; it looks like you just mixed up the installation process for the commands and the custom UI.
It seems you've already installed your commands, so just go for fixing the custom ui. I'll put the links in case you need them.
To install commands, follow the guide here:
https://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
For example, the edgeFlange.js and edgeFlange.htm files should go directly into the "commands" folder.
To install the custom UI, follow this instruction:
https://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
Take your time and try again. You'll see it's quite simple once you get the hang of it.
Hi Mala,
I will attempt to help with my observation.
I think the error for you comes from extracting "Zipped" or "compressed archives"
I have created a sample file for you to test with. A Zip file which contains only 1 single, text document named "1.txt"
You can test HOW you are extracting the contents of the file!
There are usually "2 ways" that the extraction happens. Your choice matters.
in Winzip or Winrar, the options are these:
1. Extract Files
2. Extract to 1
3. Extract Here
The first 2 methods create a folder named the same as the contents, with the contents inside that. So a folder named "1" appears, with the 1.txt file inside of that.
The last method, #3, Extracts the Contents (a single "1.txt" file) to where you chose
So with this file, experiment with how you extract it and realize when and where you get the "contents" of the zipped archive! A single text file.
With most of plugins. the "contents" are usually a js file and an htm file.
With things like customui, make sure the folder extracted is the "contents" and not a folder named as the zip.
Hope this helps
1.zip
16-35
36-42
