Full Version: Entrelacs Géométriques II - Geometric Interlacing
Show messages: All  1-4  5-11
16 Oct   [#5]
If It's the "same object" maybe you can use VClone ?
16 Oct   [#6] In reply to [#4]
Hi Zooen, do you want the script to work by clicking 3 points, the same input given to the Circle Tangent command, but instead of making a circle it makes a center point at a specificed z level?
16 Oct   [#7] In reply to [#6]
Yes, that’s exactly right.
I run the Circles Tan function, click on the three points of tangency on the edges, and the script prompts me for the Z-coordinate. In fact, it automatically handles, in the background, the creation of the circle, the creation of the circle’s center point, and the deletion of the circle, and simply prompts me to enter the Z-coordinate. The point is created in the right place at the correct Z-coordinate.
I no longer need to manually use `BoundingBoxCenter`, delete the circle, select the point and manually use `EditCenterPoint` to choose the Z-coordinate.
But perhaps it’s not quite as simple as that!
17 Oct   [#8]
I’ve just finished a new panel of Gothic interlacing. It took me less time than the previous one, as there are no Naked edges to tidy up – it’s a solid.
I’ve still got 16 panels to go… I’ve discovered a few new subtlety in MoI3D and improved my technique.
17 Oct   [#9] In reply to [#7]
Hi Zooen, here is a script to try for extracting the center point and giving a z value.
CircleTangentCenter.zip
18 Oct   [#10] In reply to [#9]
Many thanks for this script: I’ve just tried it out, and it’s saved me a lot of time!
Kind regards - Zooen
5 Nov   [#11] In reply to [#10]
New panelling
