Full Version: Heart as a pillow
Show messages: All  1-4  5-17
8 Oct   [#5]
I come closer...
8 Oct   [#6] In reply to [#3]
Will be the same! :)
Just make half part!
I have used your first section as rail of your first post, free to you to take modified section and rail! :)
When you have the half part
Make a Transform / Mirror
Message 12123.7 was deleted
8 Oct   [#8]
I cannot filllet between the heart and the skewer - what is wrong?
HeartSkewer fillet problem - moi3d forum.3dm
8 Oct   [#9] In reply to [#7]
zooen ;-)
8 Oct   [#10]
Thank you, Pilou! You put me on a very good track!!! I have since adjusted my profile line and positioned it at the top center. The result is quite close to what I had in mind. In the meantime, I have another problem - the filleting between the heart and the skewer.
8 Oct   [#11]
As a rule of thumb, its best to use loft loose for organic shapes.
The alternative is to create it as a subd mesh and import using Moi's v4 > subd > create tool.
Heart.3dm
8 Oct   [#12] In reply to [#8]
Hi Mala,
There is a little tiny edge fragment in that boundary that fillet doesn't like, here:
I repaired that by using Edit > Separate, untrim (select all edges and hit delete), then using Edit > Join to glue the pieces back together.
Note that if you have pieces that contact each other along a common edge already it can be better to use Edit > Join to glue them together and not Boolean Union because Edit > Join will only glue edges to other open edges and not try to do surface/surface intersections and remove material like the booleans are focused on doing.
You should now be able to fillet the repaired version (attached .3dm file) with a radius of 0.8 or lower.
HeartSkewer fillet problem2.3dm
8 Oct   [#13]
My solution is based on 4 steps
- Rail revolve
- Mirror
- Blend
- Adapt the dimensions
coeur.3dm
8 Oct   [#14]
With 3 spheres! :)
9 Oct   [#15] In reply to [#3]
Here is a way for you to fool around with...
Look for 2 crossing ellipses to generate the desired shape.
9 Oct   [#16]
Michael and folks, thxalo—I tried connecting it, but it didn't connect. I'm adding the workflow for the solution to my local MOI3d wiki. I'm getting close. And—all of your hearts look better than mine. I'm going to try rebuilding it, incorporating your suggestions. I think it needs to be thicker at the top when viewed from the side. Thanks everyone—I'll be in touch... cheers...
9 Oct   [#17] In reply to [#16]
Wow - this is excellent, BurrMan.
