Full Version: Modlumi , IngeTrazo: Sketchups Like !
Show messages:  1-7  8-27  28-33
9 Oct   [#8] In reply to [#7]
Pilou.
Just to let you know that virtually none of your pictures are available in my region, which is the UK.
Martin.
9 Oct   [#9] In reply to [#8]
@Blowlamp
Very curious! We are in the same continent! :)
Anyway...
You can see all my images here ... now 28 about ModLumi tell me if you can see them!
https://moiscript.weebly.com/modlumi.html
If it's for more some older ones on other threads thats normal my hosting provider https://imgbox.com/ is down for the moment! :(
Maybe you have a very strict Anti - virus with some "positives false" ? All my images can be viewed by 1 to 100 years old! :)
9 Oct   [#10]
10 Oct   [#11]
12 Oct   [#12]
12 Oct   [#13]
Not ModLumi here! (will make also that in very few time)
Take a free plugin from Open Source IngeTrazo : https://ingetrazo.com/en/extensiones
transform it with IA in Ruby langage
you obtain a rbz file that you can reload inside the free SU 2027 !
Works like a charm!
My Try!
12 Oct   [#14]
13 Oct   [#15]
Free TopMod --> ModLumi
Free Gemini
13 Oct   [#16]
15 Oct   [#17]
A new SKetchUp like! Open Source!
https://sawhorse3d.com/app/
16 Oct   [#18]
A new sketchUp like, open source!
Hew3D
16 Oct   [#19]
https://www.snaptrude.com/ Not SketchUp like but you can import SKP & Revit format!
A Bim" one with Ai ! You can have 3 projects Online but can't export anything in free!
This stair is Ai! I have drawn only the box and the 2 cylinders! :)
All the rest is Ai inside the program !
19 Oct   [#20]
ModLumi
Take a component (or components).
Perform a single copy operation (move or rotate) and confirm the copy by pressing Enter!
Type `x7 50%`: you will end up with seven components, each reduced to half the size of the previous one!
Select the result and turn it into a component! And so on...
Since you are working with components, the possibilities are endless!
You can create wild, fractal-like structures or stunning, graphic forms!
Finally, take a screenshot of your creation, send it to your favorite AI, and ask it whatever you like!
The whole process takes less than 5 minutes!
20 Oct   [#21]
21 Oct   [#22]
Free ModLumi avaible on MAC !
26 Oct   [#23]
ModLumi Gemini
6 Nov   [#24]
ModLumi ... Flow
With sounds big screen! https://moiscript.weebly.com/uploads/b/3938813-177191628195407167/camera_tracking_out_from_room_3fc08dc1_662.mp4
8 Nov   [#25]
8 Nov   [#26]
9 Nov   [#27]
