6-25
26-33
ModLumi
As it's components it's the infinite possibilities! :)
More and more poweful at the Light speed! :)
Images by Thomas Loockx
https://moiscript.weebly.com/modlumi.html
Pilou.
Just to let you know that virtually none of your pictures are available in my region, which is the UK.
Martin.
@Blowlamp
Very curious! We are in the same continent! :)
Anyway...
You can see all my images here ... now 28 about ModLumi tell me if you can see them!
If it's for more some older ones on other threads thats normal my hosting provider
https://imgbox.com/ is down for the moment! :(
Maybe you have a very strict Anti - virus with some "positives false" ? All my images can be viewed by 1 to 100 years old! :)
Not ModLumi here! (will make also that in very few time)
Take a free plugin from Open Source IngeTrazo :
https://ingetrazo.com/en/extensiones
transform it with IA in Ruby langage
you obtain a rbz file that you can reload inside the free SU 2027 !
Works like a charm!
My Try!
Free TopMod --> ModLumi
Free Gemini
A new SKetchUp like! Open Source!
https://sawhorse3d.com/app/
A new sketchUp like, open source!
Hew3D
https://www.snaptrude.com/ Not SketchUp like but you can import SKP & Revit format!
A Bim" one with Ai ! You can have 3 projects Online but can't export anything in free!
This stair is Ai! I have drawn only the box and the 2 cylinders! :)
All the rest is Ai inside the program !
ModLumi
Take a component (or components).
Perform a single copy operation (move or rotate) and confirm the copy by pressing Enter!
Type `x7 50%`: you will end up with seven components, each reduced to half the size of the previous one!
Select the result and turn it into a component! And so on...
Since you are working with components, the possibilities are endless!
You can create wild, fractal-like structures or stunning, graphic forms!
Finally, take a screenshot of your creation, send it to your favorite AI, and ask it whatever you like!
The whole process takes less than 5 minutes!
Free ModLumi avaible on MAC !
ModLumi Gemini
ModLumi ... Flow
With sounds big screen!
https://moiscript.weebly.com/uploads/b/3938813-177191628195407167/camera_tracking_out_from_room_3fc08dc1_662.mp4
6-25
26-33
