Full Version: Modlumi , IngeTrazo: Sketchups Like !
Show messages:  1-10  11-30  31-33
10 Oct   [#11]
12 Oct   [#12]
12 Oct   [#13]
Not ModLumi here! (will make also that in very few time)
Take a free plugin from Open Source IngeTrazo : https://ingetrazo.com/en/extensiones
transform it with IA in Ruby langage
you obtain a rbz file that you can reload inside the free SU 2027 !
Works like a charm!
My Try!
12 Oct   [#14]
13 Oct   [#15]
Free TopMod --> ModLumi
Free Gemini
13 Oct   [#16]
15 Oct   [#17]
A new SKetchUp like! Open Source!
https://sawhorse3d.com/app/
16 Oct   [#18]
A new sketchUp like, open source!
Hew3D
16 Oct   [#19]
https://www.snaptrude.com/ Not SketchUp like but you can import SKP & Revit format!
A Bim" one with Ai ! You can have 3 projects Online but can't export anything in free!
This stair is Ai! I have drawn only the box and the 2 cylinders! :)
All the rest is Ai inside the program !
19 Oct   [#20]
ModLumi
Take a component (or components).
Perform a single copy operation (move or rotate) and confirm the copy by pressing Enter!
Type `x7 50%`: you will end up with seven components, each reduced to half the size of the previous one!
Select the result and turn it into a component! And so on...
Since you are working with components, the possibilities are endless!
You can create wild, fractal-like structures or stunning, graphic forms!
Finally, take a screenshot of your creation, send it to your favorite AI, and ask it whatever you like!
The whole process takes less than 5 minutes!
20 Oct   [#21]
21 Oct   [#22]
Free ModLumi avaible on MAC !
https://moiscript.weebly.com/modlumi.html
26 Oct   [#23]
ModLumi Gemini
6 Nov   [#24]
ModLumi ... Flow
With sounds big screen! https://moiscript.weebly.com/uploads/b/3938813-177191628195407167/camera_tracking_out_from_room_3fc08dc1_662.mp4
8 Nov   [#25]
8 Nov   [#26]
9 Nov   [#27]
9 Nov   [#28]
SawHorse https://sawhorse3d.com/app/ Another SketchUp like!
10 Nov   [#29]
https://benchup3d.github.io/editor SketchUp Like !
11 Nov   [#30]
