Full Version: boat hull
Show messages: All  1-11  12-17
28 Sep   [#12]
I used the Sweep tool.
The green curves were used for the profiles and the red curves were used for the rails. The blue curve was used for the scaling rail.
If you show points on the curves, it's quite easy to alter the shape as required.
Martin.
loft-sweep-Martin.3dm
28 Sep   [#13] In reply to [#9]
Hi wim, thanks for posting the file.
So for the blend method you can set up a cutting curve like this:
Use Trim or Boolean Difference to make an opening:
Select these 2 edges:
Run Construct > Blend to fill in the empty area with a smooth blend surface:
28 Sep   [#14] In reply to [#6]
Hi wim, this construction method is using Loft style = "Loose" with end points to make a rounded tip directly in the lofted surface:
loose_loft.3dm
29 Sep   [#15] In reply to [#14]
Cool! :)
Like this you can keep the original forms even in Loose process!
Just make the extremities "free" (double the penultimate section for example)
You can of course transform them after!
29 Sep   [#16]
wow, thanks all, lots of approaches to pick from! will try them all and document them for my personal tutorial library! (if not I will have forgotten it next time, my neurons became a bit fuzzy lately ;-)
will try to show the result soon, a slowly rocking wooden sailboat automaton.
cheers
wim
29 Sep   [#17] In reply to [#10]
needs to be 3D printed as a test first, Pilou ;-) and yes, I forgot to reset the decimal display to 2 after some scaling tests for another project...
