Show messages: All
1-10
11-17
Hi MO,
Thanks, happy it helps you :)
Radii picker buttons: agreed, on more complex structures the radius picker can be confusing ( I found out that turning off snapping for that moment helps a bit).
Nice workflow with Blender :)!
Cheers,
Gabriel
Hey Matadam,
to use mixed radii, you need to assign a different style per curve.
When you select multiple curves, each with a different style, the script will automatically generate up to eight radii fields.
Cheers,
Gabriel
Not yet tested but can we put other profil than a circle in this script ?
Hey Frenchy Pilou,
no - not yet ;)
Cheers,
Gabriel
So wait and see! :)
Forgotten to test it! So done! :)
(very speedy test ! ) 10 seconds!
Seems we can use voronoi things and TopMod!
https://moiscript.weebly.com/topmod.html
Here just a triedre : Transform Radial Array then Multi Pipe2 but surrely more tricky to make one Multi Pipe2 triedre then Radial Array! ;)
Ps a little work to translate in French your script! :) (as soon as possible in 2 weeks :)
https://moiscript.weebly.com/tubes.html
It's that i had thought : TopMod familly result! :)
Here pure Moi - Voronoi - Flow (projected on a sphere) - Multi Pipe 2 - Gemini
Show messages: All
1-10
11-17
