Full Version: composite curve export to STEP
Show messages: All  1-4  5-9
24 Sep   [#5] In reply to [#3]
The new composite curve writer will work on arbitrary curves and not just analytic types, right? For example, a joined line-helix-arc will be output as a composite LINE-BSPLINE-CIRCLE?
- Peer
24 Sep   [#6] In reply to [#4]
Hi Peer,
I was a little off. I had just done a simple test at first and replied. THe3 video shows what I did.
Then after you responded, I dove a little deeper and discovered it was just an anomaly that wouldn't really work. I believe the end of the video shows what you experienced.
Anyway, it sounds like Michael understands and is going to be able to help you...
24 Sep   [#7] In reply to [#5]
HI Peer,
> re:
I think so, attached is an example of a joined line-helix-arc.
composite_curve3.stp
24 Sep   [#8] In reply to [#7]
Michael: Thanks for confirming. That's perfect.
BurrMan: Thanks for posting a video of what you did. That's an unexpected quirk you discovered there.
- Peer
24 Sep   [#9] In reply to [#8]
Yeah. It was odd in that it was the ONLY way it produced results. Virtually every other way gets messy results!
Just my luck....
