Michael: Thanks for working on this! Yes, composite_curve2.stp is what I need.
BurrMan: I don't understand what you mean about deleting edit points. I see 16 edit points in composite_curve.stp and deleting any of them distorts the curve when I try that. Are you saying Trim followed by deleting the mid-span points?
The new composite curve writer will work on arbitrary curves and not just analytic types, right? For example, a joined line-helix-arc will be output as a composite LINE-BSPLINE-CIRCLE?
Hi Peer,
I was a little off. I had just done a simple test at first and replied. THe3 video shows what I did.
Then after you responded, I dove a little deeper and discovered it was just an anomaly that wouldn't really work. I believe the end of the video shows what you experienced.
Anyway, it sounds like Michael understands and is going to be able to help you...
