I'm running the latest v5 beta (Apr-26, 2026) but have a strange dimension problem.,
I have 2 lines, 0.1mm difference in Z, but with claiming to be the same value (in Z). Usually, you can see which is 5.5mm and which is actually 5.4mm. Is this a display bug or do I have sound rounding in my settings?
I have set the display to 2 decimal places (also tried changing to 1dp) but no difference.
Thanks!
OK, I;m guessing buy as , when I try to move it, it shows correctly at 5.4mm
Hi James,
Where are you looking to see the z values, is it this? :
That part of the UI shows the x,y,z coordinates of where the mouse cursor is located, it does not show the z level of selected objects.
Agh, you may be right - I’ll check it tomorrow.
