Full Version: New Moi3D Era?
13 Sep   [#1]
Yesterday I played around with the new GPT Astra. I told it to model a box with some lashes in MOI.
I didnt expect anything since it probably has never used MOI before :-) but it one-shotted the box and after
telling it to only use 45 overhangs it corrected everything in one go... I have to say ham a bit baffled.
next up: reverse engineering scanned objects.. :-)
cheers from Cologne
Torsten
14 Sep   [#2] In reply to [#1]
Hi Torsten, it's interesting but the problem seems to be how to verify that it has done things correctly?
Like what if it is correct 98% of the time, can you tolerate that 2% of the time it's going to make junk?
29 Sep   [#3]
It would have to, in virtual reality, 3D print its creation and then check if the box slotted together easily or not.
Seeing AI is a random bullish!t generator, it's likely the AI would then hallucinate that it got it right when it clearly hadn't!
Only humans make good engineers. Not AI's.
29 Sep   [#4]
What was the process ?
Ai gave you a file .3dm ? (or other formats)
Or a text describing the commands to use ?
or a video how to?
or...
