Full Version: Pipe_3 plugin W.I.P.
Show messages: All  1-8  9-20
14 Sep   [#9]
I also wanted to implement another feature...
But alas, experiments showed that the sweep function (using MoI3D's mechanics) imposes limits on the distance between the profile's center (a circle, in this case)
and the polyline's starting point; if the center is too far away, the system doesn't recognize the circle as a valid object for the sweep.
!!! Upd. The issue with the array has been resolved, and I’ll soon post the updated script for your review and critique. Stay tuned for updates!
14 Sep   [#10] In reply to [#6]
Thank you for looking.
That log path is right below a “version” listing which is the filename. I couldnt find anything else.
When i renamed them i received a “pipe not found” error
But you said it works so let me try again. Maybe i had some type of glitch in my process.
14 Sep   [#11] In reply to [#7]
Hi Kraus,
I found one thing to question about the geometry, but i will have to present a case and question to Michael to ask “WHY” it is behaving that way. I couldnt figure it out on my own.
If i draw 2 “boxes” or cubes and face them apart and at an angle. I can delete the 2 faces pointing at each other and run “blend” on both open edges of the boxes and get smooth, matching surfaces that will join
Using the “segment” portion of your command, produces a nice polygonal segmentation that looks good. If i delete a segment or a couple, running blend has touching edges blend “differently” so there is a gap.
There us something about the segmented gap we need to see if ai can solve to make clean geometry. I dont know how to analyze the underlying geometry enough to understand why the “gaps”, or even if it is “normal” or unwanted.
Let me present the case in a bit. Juggling right now
14 Sep   [#12] In reply to [#11]
Hi, BurrMan!!
My AI wrote you a couple of lines here )))
"Could you post the .3dm with the problem scene (the segmented pipe with the pieces removed, before Blend)?
I'd like to look at the underlying geometry and see whether it's something the command should do differently."
I'm waiting for the file with the problematic scene (cubes, pipe);
let's try to figure out what the problem is.
14 Sep   [#13] In reply to [#11]
Hi Burr, I think that you're probably observing how Blend works differently on "natural surface edges" verses "trimmed edges".
For example here with 2 surfaces like this:
If you select those surfaces and use Edit > Show pts to show the surface control points you can see the UV structure of the control point grid.
Notice how the vertical and horizontal edges are going in the same direction as the control point grid. These are called "isoparms".
The diagonal edges are not isoparms.
If you select 2 of the isoparm edges and do Construct > Blend, you get a result like this:
The directions used with edges that are isoparms will use the other isoparm direction like this:
If you select the 2 edges that are not isoparms you will get a blend like this instead:
For edges that are not isoparms the blend direction will be perpendicular to the edge and not in an isoparm direction.
So it will be like this:
And not this:
When I get a chance to overhaul the Blend command I would like to set up an option for controlling this. But currently if it's an isoparm edge it will align to the other parametric direction but if it is not an isoparm edge it will align perpendicular to the trim edge.
burr_blend_dir1.png  burr_blend_dir2.png  burr_blend_dir3.png  burr_blend_dir4.png  burr_blend_dir5.png  burr_blend_dir6.png  burr_blend_dir7.png  burr_blend_dir8.png  burr_blend_dir9.png
14 Sep   [#14] In reply to [#11]
@Burr - and the reason why that is happening to the pipe straight segments is that those surfaces are trimmed cylinders, not ruled surfaces (like a loft between 2 curves).
You can see this if you turn on the segment surface's control points.
14 Sep   [#15] In reply to [#14]
Thank you for the great explanation and visuals! Huge help...
I will go over this with Kraus now to see if we can tune up his command, because I think it is usefull.
My results are created in his command when I create a polyline and then use the "square" and his "segmentation" option
I was confused because the result is a "square sweep" with mitered corners, with the segmentation adding the segments to the miters.
Which "should" produce even blends. Its just a square making sharp turns for each segment.
But
When I turned on control points, each segment showed points with large extensions in both directs (Much larger than the actual segment.) So we may need to ask his segmentation to be an "equal divide" so the underlying surfaces are even. Its as if his segments have varying underlying surface lengths. Random even.
I had seen this underlying geometry before, but didnt know enough about it. Like In ViaCad I see alot of "Huge torus points" attached to imported fillets or large underlying construction point objects like hidden cyclinders. I always thought of it as how ACIS did geometry. Actually a great lesson in how to model!!
Let me experiment a bit with what MoI's Regular mitered corners output vs what Krauses command creates to see if they are the same result, or if AI is going about things in a different and unreliable way... (That is the goal to help Kraus get a good, useful tool)
Anyway, enough talk. Let me dig in a bit later today, now that you explained to me what I am seeing. I'll reach out if I need any help.
Thanks again....
14 Sep   [#16] In reply to [#15]
Hi Burr, it's not particularly an "error" to have large underlying surfaces, it's a valid way to have geometry constructed.
If you like you can run the ShrinkTrimmedSrf command to reduce them.
I was a little surprised that the segment pieces were trimmed extended cylinders instead of ruled surfaces (like loft between 2 curves) but either way is valid.
But the ruled surface way would probably be a lot simpler to code because you can make something like this in just one use of the Loft command with Loft style = Straight:
That Blend behaves differently on the edge of a box versus the edge of a pipe3 elbow segment (because they are not isoparm edges) is more of a limitation in Blend where it is trying to automatically adjust behavior so that it doesn't pop up a huge set of options.
But it would be useful to be able to control that behavior in Blend so I would like to improve that in the future.
15 Sep   [#17] In reply to [#16]
Thanks Michael.
15 Sep   [#18] In reply to [#16]
The trims most certainly are at an angle to the underlying surface. My original testing I was making "Perpendicular trims" and just rotating my ends to be at the angle.
Once I understood from your explanation, I see what and why,
Thanks again.
If you DO make blend smarter in various situations, then we all win!
21 Sep   [#19]
Ok that was fun :)
21 Sep   [#20] In reply to [#19]
Very cool result! :)
