Full Version: script to
13 Sep   [#1]
Hi everyone,
I would like to create a script that creates rectangular tubing inspired from the pipe script.
Ideally i would like to create a rounded corner rectangular shape with a constant thickness.
i will try to make the complete script this week but if you could give me hand on how to make it, i will be glad.
Does anyone has information regarding the use of the rectangle factory and fillet factory ?
have a good day.
Hadrien
14 Sep   [#2] In reply to [#1]
Hi Hadrien,
There is an option in the rectangle factory for making rounded corners, it's easier to use that instead of filleting.
Here's an example:
function CreateRectangle( frame, width, height, radius )
	var rect_factory = moi.command.createFactory( 'rectangle' );
	rect_factory.setInput( 0, frame ); /* Coordinate frame with base point + x/y axes. */
	/* Input 1 can contain a corner point instead of width/height */
	rect_factory.setInput( 2, width );
	rect_factory.setInput( 3, height );
	rect_factory.setInput( 4, radius != 0.0 ); /* false = not rounded, true = rounded.
	/* Input 5 can contain a point for the rounded corner to go through instead of numeric radius value */
	rect_factory.setInput( 6, radius );
	var result_list = rect_factory.calculate();
	rect_factory.cancel();
	if ( result_list.length == 0 )
		return null;
	return result_list.item(0);
function TestRectangle()
	var frame = moi.vectorMath.createTopFrame();
	var width = 5;
	var height = 10;
	var radius = 1;
	var rect = CreateRectangle( frame, width, height, radius );
	if ( rect )
		moi.geometryDatabase.addObject( rect );
TestRectangle();
Hope that helps! - Michael
27 Sep   [#3] In reply to [#2]
Thanks Michael.
It worked perfectly !
Hadrien
