Full Version: Object doesn't export cleanly in STP
8 Sep   [#1]
I've got an object that exports cleanly in STL, but when I export it in STP, the Bambu lab slicer gets very unhappy — it can repair the object, but the repair corrupts the geometry. I'm used to seeing normaling issues, but those have always repaired correctly.
testcase.3dm
testcase.stp
8 Sep   [#2] In reply to [#1]
Hi Cuboctahedron, it may not like some slivery surfaces, see attached file.
What happens if before you export from Moi, select the object and run the ShrinkTrimmedSrf command (type the tab key, then type ShrinkTrimmedSrf then Enter?
I'll see if I can make a version with those slivers removed by mirroring the other half over.
testcase_slivers.3dm
8 Sep   [#3] In reply to [#1]
Try this one where the slivery faces have been removed.
testcase2.3dm
9 Sep   [#4] In reply to [#2]
ShrinkTrimmedSrf didn't do it. I don't have a way of re-exporting the geometry after import to Bambu labs, but attached is what it looks like. It's specifically complaining about open edges.
9 Sep   [#5] In reply to [#4]
Hi Cuboctahedron, did you test with the testcase2.3dm file above?
11 Sep   [#6] In reply to [#5]
Yes, same issue and result.
11 Sep   [#7] In reply to [#6]
have redone your model and it imports into Ideamaker slicer as stp file with no errors.
Hopefully its correct.
Barry
16 Sep   [#8] In reply to [#7]
Yeah, I already got a version of it that works — I'm sharing this to see if there's an underlying bug in the export routines that can get squashed.
16 Sep   [#9] In reply to [#7]
But thank you!
