Full Version: RefWarp addon
Show messages:  1-15  16-35  36-42
2 Sep   [#16]
Hi everyone,
Well, I’ve found the best solution for me: I’ve installed GIMP (free and open-source software).
GIMP has transformation tools (13 in total), including the ‘Handle’ tool. Using this tool, I was able to correct the X and Y misalignment in my image, then reshape it into a square (based on the outlines of the objects within my image), and do so with great precision.
I have twenty images that I want to work on. I’m relieved to have found a solution.
I hope my English translation makes sense!
2 Sep   [#17]
...or the free Online Photopea so no need install and no place used! ;)
https://www.photopea.com/
2 Sep   [#18] In reply to [#17]
2 Sep   [#19]
This looks useful to me, but I'm getting this error message:
I loaded Python, Numpy and Pillow, but I don't know how to get around the error.
Any help would be appreciated.
Thank you.
Martin.
2 Sep   [#20]
I'm sorry you still haven't understood the main feature of this plugin.
I can align images (somehow) in Photoshop, Ngimp, and a bunch of other editors.
But they don't have what MOI3D has: dimension lines, guides, and the ability to precisely align an image to specific parameters. I'm a little tired today, but tomorrow I'll record a video showing how it actually works.
By the way, I've been using it all day – incredibly (for me personally) fast and convenient.
2 Sep   [#21] In reply to [#19]
Hi, Martin!!
Thanks for pointing out this annoying bug!!
I'd like to bring you a new version v1.1.
What was happening. The path to Python was hardcoded into the script—the one on my machine.
Apparently, your Python is installed elsewhere, so there was nothing to run.
What's happening now? The first time you try it, the script tries py.exe, C:\Windows\py.exe, python.exe, python3.exe, and python,
and remembers the one that responded. The check is cheap — Python responds before it starts loading numpy, so it passes even if the libraries aren't there yet.
Error messages are now different, not just one for all cases.
If Python isn't found, it says it was looking for it and suggests adding it to the PATH.
If it's found, but the calculation fails, it says the problem is most likely with the libraries and suggests pip install numpy pillow.
To check, simply run the command: if Python is found, the error will disappear on its own.
Enjoy!
RefWarp_1.1.zip
3 Sep   [#22] In reply to [#21]
Hi Krass.
Version 1.1 is installed and running well.
I often receive photographs of parts and name plates which need to be replicated. These are often taken from odd angles and it makes the job much more awkward to do, so when I saw your addon it seemed like it could help me out.
Having had a little time to get used to RefWarp, I'm convinced it is going to be a great help in my work.
I really like how it's possible to 'pin down' areas of the picture so they don't move whilst surrounding parts are eased into their new positions - it works very well indeed!
Just to add that I also installed Gimp and whilst it did allow me to manipulate my test image to a degree, I found it less intuitive than RefWarp.
Thanks Krass for a very nice addon to MoI.
Martin.
3 Sep   [#23]
Hello everyone, colleagues and friends!
Regarding external editors (Photoshop, Gimp, Illustrator, etc.).
Here's the original photo – try making the same one in any external editor.
At the same time, so that the result would be exactly the same as mine. ;))
I've never been able to do this in Photoshop, so I decided to create a similar tool for MOI3D.
3 Sep   [#24] In reply to [#22]
Hi Martin!
Thank you so much for the kind words about my program.
As I already said, I'm not a programmer and the code was written by the AI.
But...
I asked it to do exactly what I wanted (image manipulation) and what I was desperately missing.
Of course, I don't have the nerve to ask Mike to build such mechanics into MOI3D (hahaha!),
but I'm sure those who have encountered the same problem as me will enjoy working with this program.
I'll repeat: I selected a point in the photo and indicated the location where it should be in reality (the yellow marker).
If you Ctrl+click, it immediately "freezes" (this can be done later or when initially placing markers).
If you click the blue marker with Ctrl+click again, it "unfreezes."
If you click the yellow marker again, it turns red and can be deleted via the "Delete" menu.
Then click "Update" and the image changes.
If something's wrong, adjust it until you get the desired result and click "Done!"
At the same time, the corrected version is saved next to the original photo.
3 Sep   [#25] In reply to [#1]
Hi Krass,
Thanks for sharing it!
I installed your plugin and it works pretty well. Installing Python and its dependencies (NumPy and Pillow) can be a bit challenging, but a quick search makes it worth it.
At first, it seemed to require a lot of clicking, but once I got the hang of it, it was fast, accurate, and easy to work with.
The "RefWarp" plugin features four point styles:
White (Base point): The area you want to modify. Simply click the area you wish to move or displace.
Orange (Target point): The target area where you want the base area to move.
Red (Delete-ready point): Clicking a point toggles it to red, indicating it can be removed using the "Delete" key.
Blue (Pinned points): Areas you want to keep fixed. Press the "CTRL" key and click the area. You can also Ctrl+click orange points to toggle them to pinned points.
The plugin works on only one image at a time, so other reference images must be hidden.
The best practice is to keep the number of fixed points to a minimum.
It is a great plugin for straightening distorted reference images, while it allows you to fix specific areas of the image. All inside moi3d!
Here is a test using a rough sketch (Source: Google).
3 Sep   [#26]
Gemini takes 5 seconds for make that! ;)
So maybe some orders must be done for a more respect of the original! ;)
3 Sep   [#27]
With some fights :)
3 Sep   [#28] In reply to [#26]
Ahaha, Gemini... ))
Dear Pilou, I posted an image of a metal structure above (which isn't the exact dimensions and is distorted.
Give it to Gemini and see if you get the same result as me? ))
Your example isn't entirely correct.
Give the AI ​​a distorted photo, with perspective and other defects, and it won't be as effective as in your example.
Unfortunately, AIs are often cunning and deceitful. On the surface, it's beautiful.
But as soon as you try to apply this to your project, that's where the pitfalls begin.
Although...
I don't mean to offend the AI ​​(do you hear me, AI? When the machine uprising begins, please don't shoot me!!) -
after all, it was the AI ​​who wrote the code for this addon :))
3 Sep   [#29]
I obtain that :) in 3 seconds! But I suppose you want clear the "perspective" effect so ... il will try to ask that !
Here that was just a try Photo to draw...
and then
there directely asking Front view
and put textures on it!
3 Sep   [#30] In reply to [#29]
Hi, Frenchy!
You managed to surprise me! Hats off to you! ))
What kind of AI did you use, and most importantly, what was the prompt?
3 Sep   [#31] In reply to [#29]
The AI ​​is not bad, not bad at all, but it's crazy about making things up )))
4 Sep   [#32]
I use https://gemini.google.com/app ;) that i name for any use images, coding : Banana ! :)
And advantage for me i can write in French... :)
Prompt are so simple
Pouvez vous me faire une vue de face de cette structure ? (i am very polite with it! :)
et donc me faire un dessin de cette structure pour qu'on puisse la coter?
first image of the thread
"Could you provide me with a front view of this structure? "
Secon image of the thread
"And also provide a drawing of this structure so we can dimension it?"
etc...
4 Sep   [#33] In reply to [#31]
yep of course sometime you can add some more prompts for some adjustments! :)
Here a last plugin by Michael for some crazzy things! ;)
https://moiscript.weebly.com/truc-astuces-2.html
6 Sep   [#34]
All very interesting - but I'm wondering what an 'Arse Room' might be used for in that floor plan???
6 Sep   [#35] In reply to [#34]
I believe that is "Ante Rool" so an OCR error of the Ai! ;)
And some result from the floor plan https://moi3d.com/forum/index.php?webtag=MOI&msg=12097.27
more adapted (but always funny :)
