I'm using the v5 beta and could have sworn that I read somewhere it supported file preview in MacOS.
Am I going mad?
thanks,
James.
Hi James, yes thumbnails in finder windows is supported in MoI v5.
Check that it hasn't been turned off in MOI under Options > Import/Export > 3DM options > "Write thumbnail preview image" checkbox.
Also you may need to enable the extension in macOS System Settings, under under General > "Login Items & Extensions". There should be an entry there for the v5 app and when you click the circle with an "i" in it there should be a switch that you can turn on.
They are all enabled.
Does it only work for files saved using the 5 beta?
it doesn't work for me at all (files saved with v4 or v5beta).
Hi James,
Yes saving the embedded thumbnail image is new in version 5.
3DM Files saved with version 4 won't have that.
Hi James,
What version of macOS are you using?
Do you have other programs installed that also handle .3dm files?
I'm on Tahoe 26.6.2.
Installed are:
MOI v4
MOI v5 beta
Trice (viewer only)
I have have just deleted it. Nothing has changed so I will also re-install MOI and see what happens. Will report back
edit: Made no difference.
By the way, this is the command I needed to run the app:
"sudo xattr -cr /Applications/MoI\ v5\ beta\ Apr-27-2026.app"
Hi Michael.
I can confirm this feature doesn't work for me either. [I wished it did!]
I'm on Sequoia 15.7.7
Mac mini M4 etc.
Tried using Trice but thought it was a waste of time as MacOS displays STL files in Quicklook fine without it.
Trice wouldn't work with 3DM files. Maybe it would work with Rhino, but I don't use Rhino.
OT: cmd-S working great though!
~Tom
