2-21
22
Hi Booleano,
> Why are there these differences in the number of points between figures "A" and "B"?
Probably because B is the result of a surface/surface intersection, and A has been simplified using the Rebuild command.
> Is there any way to convert figure "B" with the same number of points as figure "A", or
> at least approximately the same as "A", but with the points distributed similarly or equally?
Yes, use the Rebuild command to do that.
Set up a shortcut key, with Rebuild as the command name.
2-21
22
