Full Version: Boolean
Show messages:  1-14  15-22
6 Sep   [#15]
Hi
Why are there these differences in the number of points between figures "A" and "B"? Is there any way to convert figure "B" with the same number of points as figure "A", or at least approximately the same as "A", but with the points distributed similarly or equally?
Thank you.
Message 12088.16 was deleted
6 Sep   [#17]
Hi
This is the project; I replaced it because there was an error.
6 Sep   [#18] In reply to [#15]
Cool result on the image!
For same number of points on curve (s)
take a curve or more then Join if only one curve needed
Press Tab , Write Rebuild
Enter nb Pts wished
etc...
Message 12088.19 was deleted
6 Sep   [#20] In reply to [#18]
Hi Pilou
Thank you for liking the image; it took me a lot of work to get it, thanks to the help I received.
Regarding the curves, I know they're the same. Curve "A" is the one 777RAVEN777 suggested, and "B" is taken from the outline of 777RAVEN777's extruded image; I didn't draw it myself, which is why there's a difference. If your explanation also serves the same purpose, then that's fine with me.
Thanks.
6 Sep   [#21] In reply to [#20]
If you follow my process above you can make any curve with any number of Control Points!
here each closed curve A & B has 13 C Points! And well spaced after a rebuild!
You can select many curves in the same time and rebuild them!
If you want same length of one of the curve : make a Scale 3D (A / B) or (B / A) following result wanted ! :)
6 Sep   [#22] In reply to [#15]
Hi Booleano,
Probably because B is the result of a surface/surface intersection, and A has been simplified using the Rebuild command.
Yes, use the Rebuild command to do that.
Set up a shortcut key, with Rebuild as the command name.
