I’m not a particularly skilled CorelDRAW user myself, so I asked my colleagues (who use Moi3D and need this script) to watch your video.
Their response was that, without diminishing our respect for you in any way, they are somewhat “reluctant” to involve another piece of software in the workflow besides Moi3D and CorelDRAW. So, even though the method you demonstrated in the video is perfectly valid and legitimate, they have decided to set that option aside for their individual workflows. I hope you can understand, as they work under very tight deadlines and have quite a heavy workload. For them, the most practical approach is the one that involves the shortest possible workflow.
That said, outside of working hours, I’ll ask our IT support team to install Corel PHOTO-PAINT on their computers as a backup, because I’m sure there will be situations where the method you demonstrated in the video will be exactly what we need.
For the time being, while we wait to see whether there is a way to actually achieve transparency directly, they have agreed to place the screenshot result from the clipboard as the bottom-most layer, so that anything they add afterward can simply overlap the image from the clipboard.
Hi, Michael... Thank you for your response. We completely understand the limitation.
Unfortunately, for what we need (particularly in terms of speed and workflow efficiency) saving the viewport to a file first and then importing it into CorelDRAW is no longer practical. Our team is often working under extremely tight deadlines, and with the current workload, they frequently end up having to work overtime. Adding another step to the workflow would make things even more difficult for them.
That said, I’ve heard from our engineering designers, who generally have more flexible deadlines, that they do indeed request PDF or SVG formats, just as you mentioned, when they need a more specific or editable output. So, your response has essentially confirmed the direction of their workflow, and we sincerely appreciate your response.
