Show messages: All
1-7
8-11
Hi hadri1,
That’s because you’re selecting the curve and the points at the same time. If you only select the curve, you’ll see other information, including the segments.
The end points are not corner points, which makes sense to me. Furthermore, if, for a selected curve, the Properties panel shows you 2 segments (even if you can’t see them visually), this indicates that you have 1 corner point on your curve.
I’m adding a curve with 3 segments, so 2 corner points (and 2 end points that are not corner points).
- Zooen
How does this script (code) work?
I've tested it but I can't see any results.
Hi Zooen,
That script contains a function which given a curve returns the number of corner points in the curve.
It doesn't do anything if you try to run it all by itself, it is a building block that can be used in a larger script.
Hello Michael,
All right, very well, thanks for the information.
I’m sorting through the scripts, code, etc. that are piling up in my MoI3D folder, as well as in my .../Moi/commands folder. I’ve just realised I’ve got more than fifty commands. That’s far too many, I don’t need all of them.
As for MoI3D, Michael has opted for a lightweight approach!
Show messages: All
1-7
8-11
