Show messages: All
1-4
5-11
Thanks Pilou. But unluckily there is no information regarding the number of control points in this section.
i just checked and there is only the length value. right ?
Bonne journée
Hadri1
Hi everyone,
By 'corner point,' I mean a point that behaves the same way as the start and end points of a curve.
Meaning that it is actually "on the curve" and when i move it, the transition on each side is not smooth anymore.
when having a look at the object properties : i do not see a way to identify a curve with additional corner points.
the properties indicates 8 edit points but, there is actually 5 control points and 3 corners points (start point, end point and the one i added).
when i want to get rid of extra corner point, i usually run the fillet command.
unluckily, the fillet commande script is not the easiest for me to understand.
Hadri1
Hi hadri1,
For the case that you showed:
You can detect 3 corner points by this method:
function CountCornerPoints( crv )
var num_corners = 0;
/* Count 1 for each segment after the first segment. */
var segment_list = crv.getSubObjects();
var num_segments = segment_list.length;
num_corners += (num_segments - 1);
if ( !crv.isClosed )
/* If the curve is open add one for start point and one for end point. */
num_corners += 2;
else
/* If the curve is closed add one if it is sharp at the start/end seam point. */
var seg = segment_list.item(0);
if ( !seg.getIsG1ToAdjacentSegment(0) )
num_corners++;
return num_corners;
Hi hadri1,
That’s because you’re selecting the curve and the points at the same time. If you only select the curve, you’ll see other information, including the segments.
The end points are not corner points, which makes sense to me. Furthermore, if, for a selected curve, the Properties panel shows you 2 segments (even if you can’t see them visually), this indicates that you have 1 corner point on your curve.
I’m adding a curve with 3 segments, so 2 corner points (and 2 end points that are not corner points).
- Zooen
How does this script (code) work?
I've tested it but I can't see any results.
Hi Zooen,
That script contains a function which given a curve returns the number of corner points in the curve.
It doesn't do anything if you try to run it all by itself, it is a building block that can be used in a larger script.
Hello Michael,
All right, very well, thanks for the information.
I’m sorting through the scripts, code, etc. that are piling up in my MoI3D folder, as well as in my .../Moi/commands folder. I’ve just realised I’ve got more than fifty commands. That’s far too many, I don’t need all of them.
As for MoI3D, Michael has opted for a lightweight approach!
Show messages: All
1-4
5-11
