Show messages: All
1-4
5-8
Hi Frederick,
> I was thinking that it might be able to check/uncheck the "Both Sides" box (and
> similar things) in the dialog by using/not using a key
> Cannot be done?
A command can register a shortcut key and then do something when that key is pressed. See attached example where typing the B key works the same as clicking on "Both sides".
But it works like other shortcut keys under Options > Shortcut keys, you can't do something when the key is pressed and something different when the key is released.
Line.js
So when the dialog is first display there is no point at which the state of the control/shift/alt key can be detected and check (or uncheck) a checkbox that is part of the dialog?
Frederick
Hi Frederick,
Nope, not from script.
Hi Michael.
Understood about the limitation of script.
I was thinking of my general windows programming tool and all mouse events report the state of the mouse buttons AND control/shift/alt.
Frederick
Show messages: All
1-4
5-8
