Full Version: Modify Command Behavior With Key Held Down
Show messages: All  1-2  3-8
14 Aug   [#3] In reply to [#2]
Thanks for the example.
Do you think this ability is generally worth incorporating into v5
Frederick
15 Aug   [#4] In reply to [#2]
Tried you code and it worked fine.
I was thinking that it might be able to check/uncheck the "Both Sides" box (and similar things) in the dialog by using/not using a key
Cannot be done?
Frederick
15 Aug   [#5] In reply to [#4]
Hi Frederick,
> Cannot be done?
A command can register a shortcut key and then do something when that key is pressed. See attached example where typing the B key works the same as clicking on "Both sides".
But it works like other shortcut keys under Options > Shortcut keys, you can't do something when the key is pressed and something different when the key is released.
Line.js
15 Aug   [#6] In reply to [#5]
So when the dialog is first display there is no point at which the state of the control/shift/alt key can be detected and check (or uncheck) a checkbox that is part of the dialog?
Frederick
15 Aug   [#7] In reply to [#6]
Hi Frederick,
Nope, not from script.
15 Aug   [#8] In reply to [#7]
Hi Michael.
Understood about the limitation of script.
I was thinking of my general windows programming tool and all mouse events report the state of the mouse buttons AND control/shift/alt.
Frederick
