Michael,
I've tried editing my .ini file, but every time I make the default Mesh Angle=0, it automatically defaults back to a value of 10.
Every time I open MOI I have to change this value...I'd like to reduce the clicks :-D
Is there anyway to make my chosen value of 0 stick?
-Toby
Hi Toby, also set NoMeshAngleLimit=y and then your mesh angle setting should stick.
The reason why it will cut off at 10 by default is that setting it to very low will make extremely dense display meshes which is ok for simple files but on heavier models it will take a lot of time and consume a lot of memory.
Michael,
Awesome, thanks very much for the tip!
Cheers,
-Toby
