Full Version: How to Create PDF in Real size Scale
Show messages: All  1-3  4-5
12 Aug   [#4] In reply to [#1]
Hi vic, just to give you a visual -
Do you have units set in MOI to inches? That's under Options dialog > General > Unit system.
Then in the PDF export options, the settings you need to adjust are in the top half of the dialog:
13 Aug   [#5] In reply to [#4]
I created a 2 tier Table for my wifes Salon and used templates to cut the curves and set drill holes exactly.
Here it is,
If you zoom you can see all the drill holes in the faces. I ended up putting a covering of vinyl "flooring" on for durability and cleanup.
Its working great. Super heavy duty and durable!
