Full Version: Images in the Object Library
Show messages: All  1-7  8-13
11 Aug   [#8] In reply to [#7]
If you are a "code reader" and want to experiment with results, I would look at this line:
moi.ui.mainWindow.viewpanel.getViewport('3D').render(400, 320).save(savepath+fileName+".png");
And fool around with the render size of the screengrab in relation to the zoom value to get better results for the type of objects you use
11 Aug   [#9] In reply to [#8]
Hi BurrMan,
Thanks for the reply.
I wonder if the (400, 320) is the ideal size for the image I am supposed to create.
Maybe it's the proportions that are important.
Time to experiment.
Frederick
11 Aug   [#10] In reply to [#9]
I fooled around with it a bit....
Changing the resolution of the created png file didnt change the behavior you are after
Changing the zoom factor seems to control it better
I found a setting of "2.0" to work as you asked
The line:
vp.zoom(2.0);
With that said, I have no idea what that means
11 Aug   [#11] In reply to [#8]
Hey BurrMan,
You provided the solution.
Making sure the image ratio is 5:4 (400 divided by 320) and the image comes out nicely centered.
And Windows (I think it is part of Windows) happens to have a tool which allows adjusting an image to exactly 5:4.
Frederick
11 Aug   [#12] In reply to [#6]
Hi Frederick,
> The great thing is when you pick a part to use, it appears ready to adjust it's orientation
> to whatever surface you need, at whatever point you need it.
That's using the ImportPart command, you can run it by right clicking on File > Import.
12 Aug   [#13] In reply to [#12]
Hi Michael.
Good to know.
Before encountering that feature in the Object Library, I was importing parts and messing around with aligning them using move/rotate which was tedious.
Frederick
